Oil Archive (no new posts) An archive of oil related questions and comments.
HD cooler, need patience
Old Feb 13, 2007 | 08:16 PM
Hogaholic's Avatar
Hogaholic
Default HD cooler, need patience
Man I installed the deluxe cooler and you need 4 hands to install that sucker. I should have paid somebody to install it for me. Looks nice though.....
Old Feb 14, 2007 | 01:03 AM
Budz's Avatar
Budz
Default RE: HD cooler, need patience
Need to get the ridin' partner out there in assless chaps for a little help and diversion.
Old Feb 14, 2007 | 02:36 AM
iclick's Avatar
iclick
ORIGINAL: Hogaholic
Mine was a cinch, but its a touring model. Must be different. One snag was the 7/16" Allen adapter for the filter, which of course I didn't have, nor do most stores that sell tools.
Old Mar 7, 2007 | 02:31 PM
Soft06's Avatar
Soft06
ORIGINAL: iclick
ORIGINAL: Hogaholic
I plan on installing the HD cooler this weekend, any tips you can give me? And what's the 7/16" allen adapter?
Thanks
Old Mar 7, 2007 | 02:38 PM
sleepneagle's Avatar
sleepneagle
the allen you get with the HD allen socket set.
Old Mar 7, 2007 | 03:01 PM
Soft06's Avatar
Soft06
ORIGINAL: sleepneagle
So I need to go to my dealer and buy a set before I start my install?
Old Mar 10, 2007 | 12:47 AM
iclick's Avatar
iclick
ORIGINAL: Soft06
It's a rather simple install, except the Allen fitting that holds the filter adapter in place and screws into the filter. This requires an 11mm or 7/16" Allen wrench or socket, which almost nobody owns and few stores carry. A friend had one and bailed me out late one night, but I figured out a simple substitute. Go to Home Depot and buy a threaded rod coupler that has a 7/16" OD. This will be a hex shape and will fit inside the cooler adapter just as well as an Allen wrench. Just insert it, then place a 7/16" socket on the other end to ratchet it in place.
Sleepneagle said it's in the HD Allen socket set, but I don't see any HD tool set that has an Allen wrench this big included. My standard tool kit for the SG doesn't have it either.
Old Mar 15, 2007 | 11:16 PM
TexasBowhunter's Avatar
TexasBowhunter
Ditto on what iclick said...
This is what I just got finished using to install mine...
Old Mar 24, 2007 | 09:44 AM
Hogaholic's Avatar
Hogaholic
Update, after using it during daytona found that it lowers temps about 20 degrees. My bike would run about 20 degrees hotter than my buddies night train, now there dead even. This would work better on a bike without the wide front fender, it really doesnt get any direct airflow, but the drafts hitting it is better than nothing....
mkguitar
Aug 3, 2011 03:02 PM
lionsm13
Jun 25, 2010 09:43 PM
OldPhat
Jul 14, 2009 10:18 PM
TexFordD
May 10, 2009 11:44 PM
SPARKY01
Mar 21, 2009 10:30 PM
