Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
2002 fxd shift rod
Old Jan 30, 2026 | 01:22 PM
marcodarq's Avatar
marcodarq
ok, i have confirmed that the correct oem part you are asking about 34972-02A is obsolete and no longer available for HD, that being said, from your pix your splined dont look wasted and more ofter then not its the other lever with the internal splines that wear and strip. if you can get a good used one on ebay i would suggest that as the after market stuff is substandard.
as far as a couple of other things to get, Baker has an inner primanry bearing and seal that does NOT require having the press on and off race anymore, they work great i have lots of eperience with them.......you dont have to pull the inner primary if you ever need to pull the gearset again.
m
Old Jan 30, 2026 | 04:53 PM
Max Headflow's Avatar
Max Headflow
The shift shaft is generally hardened. The arm is what takes a ****. Chances are you'll be OK if you can keep the arm tight.. That's how it strpped in the first place. Poor matainence.
Old Jan 31, 2026 | 07:54 AM
02fx's Avatar
02fx
Yes I effed up but it won't happen again.
Old Feb 2, 2026 | 02:41 PM
02fx's Avatar
02fx
Marco just ordered these parts. Should be here next week.
Marco just ordered these parts. Should be here next week.T.Y.
Old Feb 5, 2026 | 11:01 AM
02fx's Avatar
02fx
Parts just arrived
b1gb2010
Jan 13, 2024 10:00 AM
coylizard
General Topics/Tech Tips
Jul 18, 2022 11:47 PM
Charles Kaetz
Sep 29, 2013 03:29 PM
aaron8771
Nov 28, 2012 07:17 PM
Vinsil
Mar 7, 2010 01:22 PM
