Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
hlp with throttle cable on switch cover
Old Dec 9, 2005 | 08:46 PM
Hoopman's Avatar
Hoopman
Default hlp with throttle cable on switch cover
I am attempting to install chrome switch covers on my 2006 hd roadking custom. I removed the stock cover on the throttle side and one of the throttle cables popped right out. The other however is in the cover. Can someone tell me how this cable is pulled through and then reinsterted into the new cover (both of them). ????
thanks!!!!!!
Old Dec 10, 2005 | 09:44 AM
HDF Tech's Avatar
HDF Tech
Default RE: hlp with throttle cable on switch cover
You will find a small spring around the cable end housing. You can't see it them when it is installed in the housing. If you apply enough force to the cable end from inside of the housing pushing it outward, and possible wiggle the cable a bit, it should pop out of the housing. If you can get a thin blade screwdriver between the housing and the seat on the cable on the underside of the housing (outside housing), applying some pressure here will usually pop the cable out.To reinstall the cable into the new housing, just push it in until to clicks and locks in.
apetterez
Apr 7, 2015 02:13 PM
harleyman15801
Dec 1, 2013 10:08 AM
06SGWA
Jul 4, 2013 07:02 PM
Viejo
Jun 22, 2009 12:58 PM
wlbowers
Mar 10, 2007 09:08 PM
