Thanks for the photos, some good things there to kick around. The top left photo looks easily doable. but how do you mount the spring pad they sold back in the day to kkep the banana caliper from falling onto the rotor when the mounting pins wore out?
The bottom center photo is awesome with the late model dual disc mounted to the cast swingarm. Good combination of new meets old.
Thanks for the photos, some good things there to kick around. The top left photo looks easily doable. But how do you mount the spring pad they sold back in the day to keep the banana caliper from falling onto the rotor when the mounting pins wore out?
If you have to buy a disc setup your better off with a newer style the springy thingy is not gonna work like that, but the brake still works though...the first pic has an 81-82 caliper with a 73-80 bracket abortion, but with that style caliper with the big whole on the rear of it, they sell a Y aftermarket bracket for that...the second pic is 83-84 Shovel, the last is twin cam softail...So buy what looks good to you then you just have to space it and weld a tab...
