lever Action Solenoid
Old Nov 8, 2020 | 05:08 PM
shankman's Avatar
shankman
Default lever Action Solenoid
hey i am having a hell of a time installing a lever action Solenoid. I cannot get bendex gear to engage and disengage smoothly?
I have installed Spyke hi torque starter as well. Bike is 76 FXE, replaced motor with a 80" used engine. using same clutch and i have tried everything to align gear?
I have primary cut out to see , seems like i cant retract it? i have tried washers before and after lever...... please help? Jack shaft? anyone install Spyke starters?
Old Nov 8, 2020 | 08:52 PM
megawatt's Avatar
megawatt
Are you referring to the aftermarket manually operated starter lever that replaces the inner primary mounted starter solenoid?
Old Nov 8, 2020 | 09:03 PM
TwiZted Biker's Avatar
TwiZted Biker
What primary cover & inner do you have ? Stock or aftermarket ? Some outer repop chrome ones didn't line up well, causes the bendix to bind. Anything with the name LifeLine is pure junk.
Old Nov 9, 2020 | 07:09 AM
ConfederateFLHSport's Avatar
ConfederateFLHSport
Hi. You might check the linkage for the bendix throw out. There's more than one. Depending on the inner and outer primary and clutch basket you have the angle of the pivot is different. Could cause it not to engage or bind. Hope it helps
Old Nov 9, 2020 | 07:21 AM
Hey Man's Avatar
Hey Man
I ran a manual solenoid for many years on my Shovelhead with no problems whatsoever. Hopefully you've installed it properly and have it shimmed right. Oh yeah, and if I remember right, there's that one little part, can't remember which one though, that has to be flipped around backwards to work properly.
Old Nov 9, 2020 | 07:40 AM
1981 suprglide's Avatar
1981 suprglide
check the needle bearing in the starter housing and outer primary, do the starter housing bolt run through the inner primary? if so it must be a bolt with threads all the way up or it won't line up, make sure its not a grade 8 bolt in case it falls out it won't tear up so much inside
Old Nov 9, 2020 | 06:14 PM
shankman's Avatar
shankman
inner primary is stock outer cover is Aftermarket Drag spec or Custome chrome
Old Nov 9, 2020 | 06:15 PM
shankman's Avatar
shankman
yes it is twin power or something
Old Nov 9, 2020 | 06:19 PM
shankman's Avatar
shankman
maybe cup at end with roll pin? i have tried everything ready to put original starter and solenoid on again and see what the hell is going on.....my old starter would work but solenoids wouldnt last
Old Nov 10, 2020 | 07:07 AM
ConfederateFLHSport
I had a problem with couple solenoid. Little molly powder helped. And also added couple grounds. It pulls a lot of amps and gets hot with weak ground.
jfcroni44
Shovelhead
Sep 24, 2019 08:08 AM
RedHogz
EVO
13
Apr 2, 2017 09:07 PM
88Heritage_classic
EVO
15
Jul 16, 2013 08:31 AM
bobby thumper
Jun 22, 2013 04:24 PM
hebbes
Electrical/Lighting/Alarm
May 21, 2012 12:37 PM
