Starter motor
Old Nov 26, 2020 | 07:36 PM
  #31
dogfoot's Avatar
dogfoot
Default Plug wires off
OK, plug wires off, circuit breaker off, rolled it over for 5 seconds with the button and the wire from battery to the solenoid had zero warmth.
Old Nov 26, 2020 | 07:52 PM
  #32
dogfoot's Avatar
dogfoot
Default Circuit breaker
Just for grins I put the circuit breaker back in and turned it upside down (copper terminal not on battery but on wire to solenoid). It tripped again, but the little it did turn over, you could feel warmth in the breaker.
Old Nov 26, 2020 | 08:27 PM
  #33
TwiZted Biker's Avatar
TwiZted Biker
All the big cables particularly the grounds. Something is pulling some heavy current, without the meter this is a way to narrow the suspects a bit.
Burnt contacts ( caused by heavy amp draw for several reasons) in the big relay or solenoid will cause the activation pull in coil (fed by the breaker) to draw more amps to hold engaged. Heat is a by product of this.
Old Nov 27, 2020 | 09:30 AM
  #34
78lowrdr's Avatar
78lowrdr
You have a volt meter. Test, then fix. Better yet, here is a page of choices for V drop starter testing.
https://www.freeasestudyguides.com/v...drop-test.html
https://duckduckgo.com/?t=lm&q=volt+...circuit&ia=web
Old Nov 27, 2020 | 01:32 PM
  #35
coax9952's Avatar
coax9952
Cool
Originally Posted by Fshovel Head
Thank you.Why doesn't the manual say so,instead it says to just remove the through bolts and pull out the starter.
Cause that would be more words they have to figure out how to spell right...….and draw pictures.....With Stick People.
lunyty1
Oct 13, 2020 09:07 AM
watindes
EVO
Oct 23, 2014 05:53 PM
tonycap
EVO
Mar 3, 2013 01:40 PM
89 FXRS
EVO
Jun 17, 2012 04:16 PM
SecondChance!!
Jul 5, 2011 10:03 PM
