Is there a better exhaust-to-header gasket available???
Old May 17, 2021 | 03:02 PM
D_W_L's Avatar
D_W_L
6th Gear
Default Is there a better exhaust-to-header gasket available???
I'm using aftermarket header pipes which don't align very well with the exhaust ports. So to compensate, I have been using 2 or 3 gaskets to get a proper seal. Does anyone know of a better solution? Ideally, I'm looking for something about a 1/4" thick with a bit of flexibility to allow it to shape itself to the 2 surfaces. Thanks.
Dave
Old May 17, 2021 | 03:41 PM
johnjzjz's Avatar
johnjzjz
2 different products the ultra gray sold by the box stores - forget what it says its for as it does a real good job with sealing exhaust - gaskets and pipe to pipe
then the black - the Right Stuff - its called in a tube also found in box stores is another really great sealer for anything - 0 BUT - its a thing getting it apart as its real good sealing anything - just so you know we have used a rubber hammer on some stuff to brake its seal
Old May 17, 2021 | 06:12 PM
Policeking!'s Avatar
Policeking!
I have been using Genuine James Knitted Wire Exhaust Seals #65834-98-X2, they are better than stock gaskets, Twin Cam style but sized for a Shovelhead.
Old May 17, 2021 | 07:28 PM
john lee's Avatar
john lee
they must be badly made pipes. my aftermarket pipes use the stock gaskets and havent leaked since 1984 when installed
Old May 17, 2021 | 09:41 PM
kink04fxd's Avatar
kink04fxd
I use a copper gasket and regular clear silicone. Sloober it on good. Let it cure for 24 hours. No leaks.
Old May 18, 2021 | 11:03 AM
Scrmnvtwins's Avatar
Scrmnvtwins
I have been using the original copper crush ring port side of an asbestos flat gasket flange side with pretty good luck. I believe 65834-68 was designed for the seal but I find I still need a flange gasket.
Old May 19, 2021 | 05:43 PM
DooWop's Avatar
DooWop
Can the pipes be bent to fit? Otherwise your kind of waiting for Rube Goldberg problem.
There are some muffler shops that might fix it. I haven''t seen them for awhile.
Probably easier to find some that fit.
Old May 20, 2021 | 01:59 AM
john lee's Avatar
john lee
yes with a pipe bender. ive done it my rear pipe was at the wrong angle
Old May 20, 2021 | 11:08 AM
D_W_L's Avatar
D_W_L
6th Gear
Thanks everyone for your comments. Being that the gap (on the rear cylinder only) is fairly wide, I think the best solution will be to fabricate an flange-insert of some sort. With that in place, I will then use standard gaskets on each side of it to complete the seal.
Dave
Old May 20, 2021 | 03:48 PM
johnjzjz's Avatar
johnjzjz
We had one guy make a taper insert so it sat flat when bolted and gasket the top against the head
cant pay a shop to do that its too expensive
Mountainkowboy
EVO
Jul 21, 2019 05:10 PM
mori55
Exhaust System Topics
Jun 11, 2013 02:20 PM
TedMan
Feb 21, 2012 10:23 AM
klf33
Aug 8, 2011 11:52 AM
snooper0069
Apr 12, 2009 01:00 PM
