high comp starter?
Old Mar 1, 2023 | 03:39 PM
carpenter_93inch's Avatar
carpenter_93inch
Good question, let me ask this what gauge battery cables are you running? Amps are needed to spin that starter, take a stock application say a 74 inch 8:1 comp and then look at the ground cable and the main power cable coming from the battery, not a large gauge wire right, it does the job but could be a little bigger. So, now you add comp, maybe electronic ignition more amps are needed. My thought is yes, I run 4 gauge cables, and as i posted before my routine is power on, kill switch off, lights off, crank the starter through by counting to five, kill switch on hit the button, 95% of the time hot or cold she catches and fires. The allballs starter is shorter no bracket is needed. Good luck
Old Mar 6, 2023 | 07:45 AM
TwiZted Biker's Avatar
TwiZted Biker
You need more battery CCA over 400 preferably, the All ***** 1.4KV starter and better heavier battery cable's. Did this dance with my 11.7-1 comp 93" shovel and she still grunts occasionally.
As John pointed out the ignition and timing does play a part, I run the Dyna-s with no electronic curves to worry about and retarded my timing a bit due to other factors and the crap gas we have out here.
Old Mar 6, 2023 | 12:05 PM
NO_SPRK's Avatar
NO_SPRK
I also have the dyna S ignition. the biggest battery that will fit in the box is a 325cca
my compression isn't nearly as high.
I have to check my cables today to see how big they are.
Old Mar 16, 2023 | 09:50 AM
ShovelEd's Avatar
ShovelEd
Double check your cable ground connections. (Both ends)
bigdjag
EVO
23
May 28, 2024 07:16 AM
cgmartine
General Topics/Tech Tips
Jul 30, 2020 07:06 PM
Road Star
Engine Mechanical Topics
20
Apr 22, 2017 05:42 PM
Gibler77
Sep 18, 2016 05:11 PM
6 gun
Mar 9, 2009 08:14 PM
