moded. swing arm.
Old Jun 8, 2010 | 08:04 AM
83 fxdg 90's Avatar
83 fxdg 90
Default moded. swing arm.
my 83 fxdg has a moded. swing arm. the shock bolts through the middle of the swing arm frame rather than through a block welded to the top of the swing arm. this gives the bike a grate lowered look but the belt can rub the inner primary as it gos to the drive sprocket. i have removed some metal in that ariea but dont dare to remove any more for fear the starter mounting bolt could rip out. the belt is on tight side of acceptable. i rub the top of belt with a bar of soap before a ride to keep the friction down. so iam looking at options that would give more clearance. i know rising the *** end back to original height is the best but i would rather keep soap-en and change the belt every 15,000 miles than rise the *** end.
this is the 2nd belt
thanks
not sure if pix work. i dont have permission to look at them
i must be to new
Old Jun 8, 2010 | 02:44 PM
RHPAW's Avatar
RHPAW
You should worry more about that swingarm snapping in two, now that it's been weakened by putting a shock-size bolt hole in it. It may have been slugged with a solid bar inside it, but still....... one good pothole, and you will get very real skidmarks in your underwear (if you live).
Get a new swingarm. Use lowered shocks. Do it right.
Old Jun 8, 2010 | 06:31 PM
sqdealgeorge's Avatar
sqdealgeorge
+1 on RHPAW This is dumb engineering ! And I thought HD did this sorry HD !
Old Jun 8, 2010 | 11:19 PM
megawatt's Avatar
megawatt
Have you looked into an idler pulley to adjust the slack in the belt and hold it down away from the primary case?
I don't know if it is made in a kit but I imagine something could be fabbed up.
It would have to be mounted to the swingarm to move with it.
The other thing you could do it fab up a travel limiter for the swingarm but it would bottom out on it for sure.
Have you tried setting the shock springs to their highest setting? It would make for a harsher ride but that is probably better than the hard stop that a travel limiter would cause.
<edit> Oh, I just looked again, it appears you are already on the stiffest setting.
Old Jun 10, 2010 | 04:27 AM
Shane Hutchins Sr.'s Avatar
Shane Hutchins Sr.
Have the same set-up on mine, been running it for 20 years in Maine (lots of potholes) and haven't seen even a crack yet. Bottoms out alot with a passenger on board. Running a chain, have allready replaced the inner primary once due to chain rub, an idler is the only way I can see to correct the rub. Haven't built one yet. I agree with the stance, tried a stock swing arm for a season and gotta say didn't like it. At all.
Am also running 12" shock's, she sits low.
Old Jun 13, 2010 | 07:32 AM
juscoop's Avatar
juscoop
if you want to keep the stance the idler pulley is the best option
Old Jun 16, 2010 | 02:05 AM
clb's Avatar
clb
6th Gear
it's a verry old mod done from the first days of the square swingarm,safe if done right. perhaps a smaller front drive pulley??
Old Jun 17, 2010 | 05:49 AM
83 fxdg 90's Avatar
83 fxdg 90
i should have said after market swing arm rather than modified. still probley not as strong as stock.
will look into the pulley mod but a pulley on drive side of the belt will need to be designed to meet durability requirements. has anybody done this?
the smaller front drive pulley sounds good but i would have to get a smaller rear pulley also to keep mph and rpm close to what i have now and i suppose there may not be a belt that would fit.
thanks for the ideas
Old Jun 17, 2010 | 09:35 AM
ajayrk's Avatar
ajayrk
Nothing wrong with that modification. That is sound engineering and that section is actually stronger than the stock swing arm.
Old Jun 17, 2010 | 02:23 PM
83 fxdg 90's Avatar
83 fxdg 90
that sounds good to me.
thanks.
d-streetglidr
Mar 24, 2017 11:35 PM
OddJob
Feb 15, 2016 10:42 AM
85FLHTC
EVO
15
Jan 6, 2013 07:53 AM
rideaholic
Jun 13, 2007 12:56 AM
