Starter pinion gear and clutch shell keep breaking
Old May 17, 2015 | 03:18 PM
2000softail's Avatar
2000softail
Default Starter pinion gear and clutch shell keep breaking
Hey everyone, I need some help! I have a 2001 Heritage Softail with a SE120R motor. I keep breaking the Starter pinion gear and clutch shell ring. I just replaced everything and went to start it and broke a few teeth off the new clutch shell for the second time. I have ACR's in the bike and they seem to be working. Also have a high torque starter. Is there anything I can do to stop this from happening again I can't keep paying $400 for a new clutch shell? Any help would be greatly appreciated. Thank You
Old May 17, 2015 | 03:43 PM
Tom84FXST's Avatar
Tom84FXST
Sounds like you have a mismatch between your pinion and ring gears...even if your ACRs were not working, it should just be hard to start...not immediately break...how many teeth on the pinion...how many on the ring gear?
Old May 17, 2015 | 03:45 PM
2000softail
The Pinion gear is a 10 and shell is a 102
Old May 17, 2015 | 03:52 PM
Tom84FXST's Avatar
Tom84FXST
With that motor, you would probably want to change it to a 9/66...they are a lot stronger.
http://www.kandgcycles.com/spyke-rin...HAQ#googlebase
Old May 17, 2015 | 04:02 PM
2000softail
How would I remove the old ring gear? The one on my bike has rivets in it
Old May 17, 2015 | 04:07 PM
Tom84FXST's Avatar
Tom84FXST
The picture of the kit I posted doesn't show it, but usually they come with bolts...just drill out the rivets and bolt it on.
Old May 17, 2015 | 04:14 PM
2000softail
Ok thank you so much for help
Old May 17, 2015 | 04:24 PM
2000softail
Two more questions would this work http://shop.evolution-industries.com...product_id=106. Also should I change my compensating sprocket
shovhd
EVO
16
Dec 19, 2018 03:50 PM
2000softail
May 17, 2015 11:19 PM
scot210
Jul 6, 2011 06:10 PM
mangler
Mar 21, 2008 12:56 PM
Spitshine
Ironhead
Apr 24, 2007 09:54 AM
