Carburated 88 issue
Old Jul 11, 2016 | 07:03 PM
Nightrain00's Avatar
Nightrain00
1st Gear
Default Carburated 88 issue
Today I went for about an hour ride. Everything was normal, it ran good. I came home ate dinner, and went back out to start it. When I did it made a pretty loud pop and then while it was running it was making a sound kinda like when a spark plug is out of an engine, like a compression leak, but a big one. It won't idle. And the air sound seems to be coming from between the cylinders, behind the air cleaner.
Any help is greatly appreciated.
Old Jul 11, 2016 | 08:05 PM
tmilo1000's Avatar
tmilo1000
Any mods to the engine? Cam tensioners replaced?
Old Jul 11, 2016 | 09:03 PM
langwilliams's Avatar
langwilliams
intake gasket?
Old Jul 11, 2016 | 09:04 PM
Nightrain00
1st Gear
I bought it used 2 years ago with 11k miles, I'm pretty sure it was all stock. I checked the outer shoe last fall and it was worn but didn't look too bad, so I planned on riding it this summer and putting the heat drive in this winter.
Old Jul 11, 2016 | 09:06 PM
Nightrain00
1st Gear
I was hoping intake gasket, but the more I think about it, intake should be a continuous sound not a chuffing?
I'm starting to think head gasket, which is really making me angry.
Old Jul 11, 2016 | 09:11 PM
mrlexus's Avatar
mrlexus
I have seen a twin cam backfire and blow the cv carb off the round gasket. Take off the air cleaner and back plate and make sure it's pushed into the manifold gasket correctly.
Old Jul 11, 2016 | 09:22 PM
Nightrain00
1st Gear
It did sound like a backfire, I'll try that first thank you sir.
(Fingers crossed)
Old Jul 20, 2016 | 10:02 PM
Nightrain00
1st Gear
That's all it was, it backfired and blew the carb off the manifold. So is there anything I can do to prevent this from happening again?
Anthony8858
Exhaust System Topics
13
Feb 25, 2019 04:00 PM
shaker
Mar 2, 2014 08:37 PM
moparbobby
Sep 21, 2012 01:22 PM
gsgtrman
Jul 30, 2008 10:51 PM
HDF Tech
Engine Mechanical Topics
Aug 2, 2005 09:09 AM
