O ring size for oil drain plug 2005 FXSTBI
Old May 22, 2017 | 12:28 PM
MThompson802's Avatar
MThompson802
Stage I
Default O ring size for oil drain plug 2005 FXSTBI
Looking for the o ring size on the oil drain plug for a 2005 Night Train FXSTBI?
Old May 22, 2017 | 04:22 PM
Tampa Fatboy's Avatar
Tampa Fatboy
Take the plug down to ACE. Worse scenario pull the primary plug and take that 'o' ring down to ACE.
Old May 22, 2017 | 05:27 PM
GADAWGFAN#1's Avatar
GADAWGFAN#1
I took my old o ring off and to autozone...it was cheaper to buy this little kit that had a variety of sizes...just a few bucks and it had a shitload of the correct size rings in the kit..
Old May 22, 2017 | 09:40 PM
hog-doc's Avatar
hog-doc
11105 at ANY Harley dealer in the world! Guaranteed to fit AND seal!
Old May 22, 2017 | 09:51 PM
Bluraven's Avatar
Bluraven
Harbor Freight.
$8 without a coupon and you'll never need to go buy another o-ring for the rest of your life.
https://www.harborfreight.com/382-pi...ent-67554.html
Old May 25, 2017 | 09:21 AM
hattitude's Avatar
hattitude
I got this cross reference info, from this forum, several years ago and saved it:
Harley oil plug/tranmission plug/ primary case plug O-ring HD part #11105
size/cross reference #013
Viton is best but Buna-N are OK
The o-ring is 9/16 o.d. x 7/16 I.d. with 1/16 cross section (thickness).
I get my #013 o-rings at McMaster Carr......
100 pack, O-rings, Buna-N/ oil resistant, MMC #9452K57, $4.13
50 pack, O-rings, Mil-Spec Viton / chemical resistant, MMC #1201T24, $8.20
Old May 26, 2017 | 05:43 PM
GADAWGFAN#1
Buna N is fine for this application. Most of the damage on these is done via mechanical abrasion from taking in and out...100 pack will last years.
Old May 26, 2017 | 10:09 PM
o/d's Avatar
o/d
my 2002 fxst uses 9/16" od x 7/16" id, 1/16" thick. I've been using ones from hardware stores for years no problems
jharleyrider
Oil Archive (no new posts)
May 5, 2017 05:11 PM
Coastiejosh
Nov 18, 2012 11:38 PM
johnica
Aug 30, 2012 11:11 PM
treehawk
Apr 12, 2010 06:21 PM
tprkt
EVO
Oct 17, 2006 08:13 PM
