Air Intake Question
Old Jun 25, 2017 | 01:46 AM
RoadTrippin''s Avatar
RoadTrippin'
Default Air Intake Question
I have '13 Heritage, If I change my air filter to a better filter (more air intake) do I need a retune?
Old Jun 25, 2017 | 06:35 AM
Bone Doc's Avatar
Bone Doc
Yes.
Harley's run lean from the factory. Adding more air without changing the fuel will make it run more lean. This will cause an increase in engine and oil temperatures and negatively effect performance.
Most here would have you avoid the HD download because it will still have your bike running lean. There are numerous tuners available to enrich your AFR. Peruse some of the links here.
Again, to answer your question, if you add a heavy breather air cleaner you will need to remap the ECM.
Old Jun 25, 2017 | 07:20 AM
RANGER73's Avatar
RANGER73
No, With out changing to pipes it won't suck any more air (at least not enough to make a difference). Because it has nowhere to go.
Old Jun 25, 2017 | 07:25 AM
Iceman24's Avatar
Iceman24
I'm more of a "err to caution" kinda guy, when it comes to vehicles. IMO...get a tuner and adjust. There are tons available, ranging from mid $100's to $500. It's probably not your last mod and this way you're set for future upgrades.
Old Jun 25, 2017 | 12:38 PM
RoadTrippin'
I did add V&H slip on exhaust. And i would think that changed my exhaust out put.
Old Jun 25, 2017 | 07:32 PM
RANGER73's Avatar
RANGER73
Didn't see that in your post. I was answering the question you posted.
Old Jun 25, 2017 | 10:31 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
If you are going to install a less restrictive flowing intake which includes a better element along with a bigger/better backing plate(Stage1) leading into the throat of the throttlebody but you leave your stock exhaust in place, NO, you do not need an adjustment to the A/F ratio via a fuel management device. Once you change the OEM exhaust out to a better system, all bets are off the table!
Old Jun 26, 2017 | 05:23 AM
touchdown's Avatar
touchdown
A/C and slip on's NO add a header yes
BobRR
Mar 7, 2019 03:51 PM
tripleb1911
Sep 19, 2014 03:53 PM
iron ace
May 15, 2011 03:55 PM
DWGMan
Oct 13, 2007 11:28 PM
yodal
Aug 13, 2005 03:06 AM
