Hot Bike - Won't Turn Over
Old Jul 7, 2017 | 06:16 AM
tigercreek's Avatar
tigercreek
Default Hot Bike - Won't Turn Over
2000 FSTD w/TC88 and Mikuni Carb - 33K miles.
After getting the bike hot this morning and stopping for gas the bike would not start (barely turning over - like heavy compression) until it sat and cooled for about 15 minutes. First time this has happened.
Like many, I have hot hard starting issues that are fuel related - but they are solved with a slight twist of the throttle - and the starter/motor always spins.
Battery and cables are good.
Since I am at work now and have all day to think about it, where should I start my search for the problem?
I am assuming it is electrical and some little voice in my head is saying ignition module, bad ground connection or starter.
On the right path?
Old Jul 7, 2017 | 06:30 AM
1340hog's Avatar
1340hog
Sometimes when a starter gets hot they begin to seize up,If this is the case it will sooner then later completely seize up.this may or may not be your problem.Its just something to keep in mind during your diagnostic process.Also you say the battery is good ,Have you load tested it??poor cranking amps will cause this issue.
Old Jul 7, 2017 | 06:44 AM
tigercreek's Avatar
tigercreek
Battery is 6 months old and was kept on a trickle charger during winter days it was not ridden. But it has not been load tested.
Old Jul 7, 2017 | 09:05 AM
bluzman24's Avatar
bluzman24
I had the same problem (07 Night Train -TC 96). I replaced the starter spragg clutch (around $40) ,all good. Goodluck.
Old Jul 7, 2017 | 01:12 PM
tigercreek's Avatar
tigercreek
Left work. Dead bike.
Got it jumped off and came home. First check was voltage and the stator is putting out 10.5 volts.
Bad stator.
Old Jul 8, 2017 | 10:12 AM
tigercreek's Avatar
tigercreek
Correction - bad rectifier.
Everything else tested good.
Of course no one around here has one.
Looks like I'm parked for a while.
Old Jul 8, 2017 | 10:33 AM
hattitude's Avatar
hattitude
If you gotta wait.... might as well order one online form Cycle Electric....
They make good stuff...!!
I've only had to replace one regulator/stator/generator through all the years, on all my bikes... but when I did, I used a replacement from Cycle Electric... consider it an upgrade.
Good luck...
http://cycleelectricinc.com/
Old Jul 8, 2017 | 01:55 PM
tigercreek's Avatar
tigercreek
Thanks for the info. Got one on the way.
Old Jul 9, 2017 | 03:09 PM
the blob's Avatar
the blob
Glad you found it, mine was the opposite
On my 2000 it was making my Speedo read
Whackey. When I checked the voltage
It was at 19.6 volts at 1000rpm! Bad
Regulator lol.
Old Jul 10, 2017 | 10:15 AM
tigercreek's Avatar
tigercreek
The stator was not grounded out and put out good ac voltage when disconnected from the rectifier and the bike running.
With everything connected and the bike running (after being jumped off) voltage at the battery was 10.6 volts.
With everything connected and the bike off, I removed the negative lead from my battery and measured the voltage between the negative terminal of the battery and the negative battery lead - 9.6 volts.
That lead me to believe the rectifier was allowing the battery to bleed down - plus the fact that it was not sending charging voltage to the battery - means a bad rectifier.
Glad that is the case since I was not looking forward to changing another stator.
TwincamJim03
Jul 7, 2013 11:28 AM
03psd
Sep 17, 2012 10:13 AM
jjslips
Jul 12, 2012 10:30 AM
tmf2
Jul 31, 2007 10:03 AM
77ironhead
Ironhead
Jun 18, 2007 04:03 PM
