Handlebar vibration
Old Oct 18, 2017 | 04:55 PM
Rollon's Avatar
Rollon
Default Handlebar vibration
Ok guys, i know some folks think it is nonexistant, but i have vibs strong enough to put my right hand to sleep at about 2400 rpm in 5th and 6th gears.....i added a little weight to the right side with a ram mount for my gps, that only changed the rpms of the vibration. In the past i have tried handlebar bushing, bar changes, and a few other tricks... I do have cruise control and that's great under highway conditions, but going thru small towns and short runs around towns with stoplights still put my hand to sleep. I have a 2016 heritage. Anyone tried the bar snake or chubby bars?
Thanks!! I'm looking for solutions that you found that worked, the local dealer had no recommendations!
Old Oct 18, 2017 | 05:06 PM
DrPlastic's Avatar
DrPlastic
Try installing a set of handlebar weights to even out the weight and balance the bars. Since you added the weight you can even put a roll of pennies up inside the left handle bar.
https://www.bikebandit.com/aftermark...8aAhrbEALw_wcB
https://www.google.com/search?q=hand...w=1536&bih=740
Old Oct 18, 2017 | 05:40 PM
berniemc's Avatar
berniemc
I have 3 softails and they all do that and feel it in floorboards and seat.93 EVO is th worst.
Old Oct 18, 2017 | 05:53 PM
Rollon's Avatar
Rollon
Dr Plastic, thanks for the input! Have you used the weights? if so, how much weight or do they not have different weights? Thanks for Serving and putting in your 20 yrs!
Berniemc-- I had a RoadGlide that I changed risers on to pull the bars back, it vibrated at highway speeds. Once HD produced the Ultra Low I got a set of those and used the stock riser and handlebar bushing; that eliminated the vibs!
Old Oct 18, 2017 | 06:52 PM
kenny55's Avatar
kenny55
My sportster was a vibration machine! So I bought these and they helped a lot.
http://www.bikernet.com/pages/The_Vi...ng_Device.aspx
Old Oct 18, 2017 | 07:04 PM
Booda_do's Avatar
Booda_do
Default Vibranator
Vibranator Tuned-Mass Dampers
Looks like they are no longer in business - regretfully.
I swear by these. I've been riding for nearly 35 years - all different bikes. Finally found the one I wanted (2009 Night Train) and before I knew it within 30 mins. of riding my right hand would tingle and clamp up (fist pump). Nothing I could do - different bars and grips - nothing.
Came across Vibranators - no longer an issue at all. I can ride all day without tingling. I am sure it works differently for different physiology's but for me - I no longer suffer from the tingling or cramping.
If you can find them - definitely snag them.
The owner was a great help and tremendous person - highest regards.
Old Oct 18, 2017 | 07:20 PM
kenny55's Avatar
kenny55
Actually, i initially could not find them either. I checked and I bought them from Steiger Performance.
Come to think of it, electronic throttle may not allow installation of these because right side handlebar has the throttle pot inside the bar.
Old Oct 18, 2017 | 07:52 PM
DrPlastic's Avatar
DrPlastic
I purchased a used Suzuki Boulevard back about 13 years ago and it was missing one of the factory installed weights and the bars vibrated. I went to the dealer and bought a replacement and it smoothed them right out!
Old Oct 18, 2017 | 08:44 PM
Rollon's Avatar
Rollon
Yes, I've heard about those and checked out the articles. That's the same approach as putting bird shot in a small case and stuffing it into the bar; which does work! My 2016 Heritage is TBW, so that's not workable without major changes. Thanks for the inputs!
Anyone else tried something that worked?
Old Oct 19, 2017 | 12:28 AM
jkinner's Avatar
jkinner
I changed the risers on my 16 Deluxe, brought the bars 2" up and 1" back, seems to have solved my problem, (I do have carpel tunnel in both hands though).
