2018 Speedometer Condensation?
Old Aug 16, 2018 | 08:40 AM
  #81
FrankEV's Avatar
FrankEV
Originally Posted by blackSP
Thinking along the same lines I have stuffed the big gap under the console to stop cold air hitting the speedo.
Or hot air, dry air, moist air. The damn thing always fogs up anyway.
Hard to tell from the photo where you "stuffed" the foam. That being said, the foam will not keep air from infiltrating into the console. Too porous.
Old Aug 16, 2018 | 09:20 AM
  #82
Pitbull_Dallas's Avatar
Pitbull_Dallas
We've had four or five days of rain here. Yesterday was nice day so I rode about 120 miles, in the sun. My speedo fogged up at the bottom. Meh, no problem, it always does that. As I've said in other similar threads, they do that. Accept it and move on. I've been riding for 48 years, all harley's and they've all done that. I've never had one that had the glass stain from the condensation.
Old Aug 16, 2018 | 09:30 AM
  #83
ole_phart's Avatar
ole_phart
Let's see what happens!
Used this stuff
To fill this gap.
2 minutes work and easy to remove
Good idea! Let us know, if that works the wife-person might find a hole in our mattress topper.
Old Aug 16, 2018 | 09:32 AM
  #84
ole_phart's Avatar
ole_phart
I've had 4 that haven't. Just sayin'.
Old Aug 16, 2018 | 10:39 AM
  #85
cmhdwg09's Avatar
cmhdwg09
Originally Posted by FrankEV
How long have the dry packs been under the console? Mine took about two weeks before they absorbed all of the moisture and the speedo stopped foging. Give them time to work.
My bike is parked outside under a car port so I don't have any significant change in temperture between when parked and when out to ride. If parked in a cool garage it may contribute to moisture infiltration. It may take longer for the packets to absorb the moisture out of the speedo.
In my case, they were placed around a brand new speedo....there was no moisture to absorb. This speedo is worse that either of the other 2.
Old Aug 16, 2018 | 04:13 PM
  #86
blackSP's Avatar
blackSP
Maybe this pic clarifies
Old Aug 16, 2018 | 04:37 PM
  #87
FrankEV's Avatar
FrankEV
The overhang on my Heritage console is no where as big as what you show. I can hardly poke my little finger under it where some wires pass through.
That foam may block out some rain that might blow up and under the console, but not likely to keep moist air from geting in.
Let us know if it makes any difference.
Old Aug 16, 2018 | 05:07 PM
  #88
Mike Ci's Avatar
Mike Ci
Stage I
Default Fogging Speedo
2018 Heritage...
Mine is fogging so badly I cannot read the speedometer, much less the gauges. HD of Tallahasse stated there is a 2 month back-order.
I call HD corporate got a case number. I have had HD for nearly 45 years...I will not accept a brand new motorcycle ( 2 months)
If I don't receive a speedo within a couple weeks I will be reporting it to FL business bureau and contacting an attorney.
2018 ..There is no excuse for such lax quality..Oh did I mention I can hear my gas gap rattling at 60 MPH...
Indian is starting to look better...OK done ranting....
Old Aug 16, 2018 | 09:13 PM
  #89
uklauren's Avatar
uklauren
Florida Crew Moderator
They are replacing my speedo this weekend
Old Sep 1, 2018 | 10:06 AM
  #90
blackSP's Avatar
blackSP
Default Still. Moist. Fix. Did. Not. Work.
Used this stuff
To fill this gap.
I can confirm this doesn't work.
Same ****, moist in speedo. Dry and sunne day, bike hasn't seen any water in a while.
I'm sooo disappointed 😥 😥 😥
