2012 FLSTC Fuel Lines "HELP"
Old Aug 9, 2020 | 07:24 PM
speediseverything's Avatar
speediseverything
4th Gear
Default 2012 FLSTC Fuel Lines "HELP"
Bike is a 2012 FLSTC. I am changing out the fuel regulator housing in the tank and i am having a hard time trying to purchase the 2 fuel lines in the tank. The 2 lines are the check valve and the fuel line together and the other is fuel line that goes from the pump to the regulator. I have searched on line and the dealer is no help. Any help is greatly appreciated
Old Aug 9, 2020 | 07:33 PM
Capt_Salty's Avatar
Capt_Salty
I well understand...
I found the line from the tank to the intake here: https://www.denniskirk.com/goodridge...prd/188578.sku .
Then I located a new check valve assembly: https://www.jpcycles.com/product/100...y-oem-62189-08
While I am replacing the fuel filter, I do not plan to change the "other" internal hose at this time... hope that's not a mistake...
Searching thru the parts catalog (https://serviceinfo.harley-davidson....iew?id=273167#) I found H-D numbers and then googled away to locate other parts.
Hope this helps...
Old Aug 10, 2020 | 02:23 AM
S.D.M.F's Avatar
S.D.M.F
Old Aug 10, 2020 | 11:51 AM
hattitude's Avatar
hattitude
I have not done this myself, but I have read where some people just replace the hose with a good quality, submersible fuel line hose like the Gates #27097. My understanding is that versus OEM tubing, the good quality fuel hose is much stiffer than the thin tubing used OEM... not sure if that would cause any issues with reassembly/fitment or not..
Not sure what key words to use, but I have read threads about it on this and other forums... maybe try a search and see what you find..
Otherwise... be safe and just get the OEM parts...
Good luck with the repair...
Old Aug 10, 2020 | 07:26 PM
speediseverything
4th Gear
Awesome guys. Huge thanks
Old Aug 10, 2020 | 10:19 PM
Capt_Salty's Avatar
Capt_Salty
Hope it all works out for you! I'm still waiting on the check valve line & fuel filter to arrive... If I had any idea how slow J&P would be with my order, I'd gone with Amazon...
Old Aug 14, 2020 | 02:22 PM
Capt_Salty's Avatar
Capt_Salty
Parts finally showed up and with lots time and frustration... I finally got the new check valve & filter installed.
Now for the $64,000 question: What's the majik process to get everything "primed" again?
The bike fire a couple of times but then quits.
I'm guessing some sort of vapor lock/air-in-line problem???
TIA!
Old Aug 14, 2020 | 08:09 PM
Capt_Salty's Avatar
Capt_Salty
Never mind... Turns out the fitting wasn't completely in place... Grrr... At least my bike is ready to ride again!
Old Aug 14, 2020 | 10:13 PM
bad tappets's Avatar
bad tappets
I replaced all the tank guts on my ‘06 a few years ago. Used Gates submersible hose. Worked fine.
Capt_Salty
Aug 9, 2020 06:49 PM
randazlr
13
Jul 13, 2017 10:36 AM
kjelders
Jun 22, 2012 03:43 PM
Bogey_52
Mar 17, 2009 11:08 AM
mile hi
Oct 23, 2007 03:31 PM
