H-D ECM failure???
Old Feb 14, 2021 | 10:20 AM
swifty's Avatar
swifty
Thanks for the update....swifty
Old Feb 14, 2021 | 12:52 PM
hattitude's Avatar
hattitude
Glad it is all fixed......!
Did the dealer say you had a bad engine temp sensor, and they believe that was the culprit....??
I'm just curious, because the fact that you needed a new voltage regulator and stator, could have been the problem too.... I know that on any vehicle that uses electronics/computers to run, like HD EFI bikes, when the voltage gets shaky, all sorts of things go crazy....
Anyways... now you get to just ride.... And that's the point of it all....
Old Feb 14, 2021 | 04:21 PM
Capt_Salty's Avatar
Capt_Salty
The work was done at my indy... when the bike started throwing the battery light (after replacing engine temp sensor) is when they found the stator & voltage regulator problem.
I have now put well over 100 miles on with no idle issues!
Old Feb 14, 2021 | 04:56 PM
WKNDS's Avatar
WKNDS
Do you know HD replacement stator/regulator were used? or did they use
something better - like from Cycle Electric ?
http://cycleelectricinc.com/RECTIFIER.html
thanks,
T.
Old Feb 14, 2021 | 05:12 PM
Capt_Salty's Avatar
Capt_Salty
thanks,
T.
No, I do not know... But I'll try to find out on Tuesday.
Doug F
Jan 11, 2018 07:38 AM
PappyUSMC
May 7, 2013 10:21 PM
Molzy
Jan 3, 2010 03:19 PM
globetrotter
General Topics/Tech Tips
Jun 27, 2009 02:11 AM
debay
Aug 2, 2008 04:25 PM
