Lowering FXSTC front end around 4 inches?
Old Apr 18, 2021 | 10:54 AM
Evo91's Avatar
Evo91
Default Lowering FXSTC front end around 4 inches?
I have a 1990 fxstc. I would like to eventually put the heritage/fat boy trees and upper fork tubes on it but don’t wanna spend the money right now. Could I get a heritage drop in lowering kit and it work? Or will that lower it too much for the length of the stock tubes?
Old Apr 18, 2021 | 11:01 AM
60Gunner's Avatar
60Gunner
Lowering the front is like raising the rear...beware of a higher speed wobble.
Old Apr 18, 2021 | 02:53 PM
Evo91's Avatar
Evo91
I have air ride in the rear so I’m not worried about that I just want the front lower and don’t wanna have to double buy things.
Old Apr 18, 2021 | 03:14 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I don`t get it, the Heritage fork tubes and sliders are not the same diameter as the fork tubes and sliders on your bike.
Heritage Drop In Lowering Kit?
Old Apr 18, 2021 | 05:36 PM
Evo91's Avatar
Evo91
yes....41mm? 22.25 length for the flst and the fx has 24.25 length. So a “drop in kit” progressive lowering kit will have shorter springs. For the heritage than the fx’s
Old Apr 19, 2021 | 10:53 AM
MCSarge's Avatar
MCSarge
Yes you can use the same kit for both bikes. Progressive lists the part # as 10-2003, but Progressive is out of stock. Progressive states: Pull up to two inches out of the front end of your bike without the hassle of disassembling the forks or even changing out the oil and the whole process can be done with basic tools!
Fits:
PRODUCTS : 1990 HARLEY DAVIDSON FXST/FLST - Standard / Custom / Heritage / Heritage Classic / Heritage Nostalgia / Fat Boy / Night Train
Your only going to get 2" out of this kit, but you can also change the front wheel to lower it some more. Good luck on your project.
Old Apr 19, 2021 | 10:58 AM
Evo91's Avatar
Evo91
Fits:
yeah I was looking more at the kits and noticed it worked for both. I thought they were different kits. Thanks for the help! I’ll just go with that one till I can get the shorter fork tubes and trees.
Old Apr 19, 2021 | 03:55 PM
MCSarge's Avatar
MCSarge
You can only drop so much in the front before you start dealing with the fender hitting the lower tree and a really rough ride. I would take the 2" out of the suspension and then switch over to a 16" front wheel to get the rest, that way you have a cushion for any unforeseen big bumps. Talked to a guy Saturday who lowered the front of his Street Glide when he put his 21" wheel kit on and he hit a huge bump and creased his newly painted custom fender. Sucks that he just paid some company 5 grand to do the work and now they have to fix it......Good luck on your project.
Old Apr 19, 2021 | 10:20 PM
Evo91's Avatar
Evo91
Yeah that wouldn’t be good. Lucky for me, I don’t have a front fender so I don’t need to worry about that. I’d actually like to get a 21x3.5 front wheel so I can run a larger profile tire in it.
06hdsofty
Jan 13, 2017 07:46 PM
Ride my Seesaw
Apr 25, 2013 03:30 PM
ssrgeoff
May 25, 2011 03:10 PM
rounder
Nov 9, 2009 01:41 PM
TheeBoy
Jan 16, 2008 01:46 AM
