Handlebar Change
Old Jul 30, 2023 | 04:09 PM
drm1978's Avatar
drm1978
Default Handlebar Change
Hey Folks,
The grip position on my 2015 Heritage Classic causes an ache in my upper back after only 30 minutes or so of riding. Now, I'm 63, so pains are not uncommon, but I believe (based on the riding position of my other bikes), that if grips were perhaps 3" (or more) closer to me, I'd be much more comfortable. I can't be positive since I didn't buy the bike new, but I'm assuming the handlebars are the stock 56569-09 part. From what I could find, the dimensions are:
1" Diameter
32.5" Tip-to-Tip Width
7" Pull Back
10" Rise
11.5" Base Width
3.14" Knurl Center-to-Center
So, what handlebars would you folks suggest? Should I just get an after-market bar with a 13" rise (or more), and then angle it further back that my current bar? If I go that route, at what point will I have to get longer cables? I'm not afraid of doing the work, but if I could get a more comfortable ride without dropping a ton of money on cables and brakelines, I'd be thrilled!
Thanks!
Dave
1993 Ultra Classic
2012 Sportster 883 Super-Low
2000 Low Rider (for sale!!!)
Old Jul 30, 2023 | 04:22 PM
Bone Doc's Avatar
Bone Doc
Why not loosen the handlebar clamp and rotate the existing bars back towards you.
Old Jul 30, 2023 | 04:42 PM
drm1978's Avatar
drm1978
Yeah, that's probably a simple thing to try, but I was hoping to keep the grips at the same height relative to my body. But, it definately won't require new cables! Thanks!
Old Jul 30, 2023 | 08:14 PM
Rhino2008's Avatar
Rhino2008
6th Gear
These might work
Old Jul 30, 2023 | 08:26 PM
drm1978's Avatar
drm1978
Originally Posted by Rhino2008
These might work
What's the make and part number? Thanks!
Old Jul 30, 2023 | 08:29 PM
Rhino2008's Avatar
Rhino2008
6th Gear
Pretty sure they are Harley brand, no part number. They were on the bike when I bought it.
2008 Softail Deluxe
Old Jul 30, 2023 | 08:35 PM
Rhino2008's Avatar
Rhino2008
6th Gear
Different angle
Old Jul 30, 2023 | 09:04 PM
Buddy7394's Avatar
Buddy7394
I used to get Heritage Bars from the 90's Evos.. They did the trick & cables were long enough..
oldguyriding
Mar 5, 2013 09:57 AM
Gates1960
Sep 9, 2011 11:54 PM
FLSTCI nut
Sep 24, 2010 06:08 PM
jimmers1817
Mar 9, 2009 10:51 PM
08roady
Aug 28, 2007 05:29 AM
