Hi I have a 2019 lowrider M8. Last year my engine sumped and I got that dealt with which was not cheap. I just brought the bike in for an oil change and all other
fluids. The other day I checked the oil level and it was twice as high as the dipstick line.. I just got it changed a week prior.. what is going on I’m stressed right out. My mechanic said there could be a leak from my primary that is sending it over. Any thoughts? I don’t have a ton of extra cash at the moment if it will cost thousands to fix. Suggestions?? Thank you very much.
Well, I guess that is possible, but...
I'm no expert on Harley lower ends, and maybe the M8 is different, but the engine is separated from the primary by the crank shaft seal. In the one case I knew of personally, and several I have read about on forums, whenever that crank shaft seal leaks, the engine oil transfers from the engine to the primary....
Yours would be the first case I have been made aware of where a leaking crank seal led to oil transfer from the primary to the engine...
I feel the most likely reason is that the mechanic overfilled it, and you made one of your oil checks improperly... or it is at the correct level and you made one of your oil checks improperly..
I'll be curious to read what you eventually discover....
So I just re checked. My engine oil is still much higher than supposed to be. My primary is definitely low.. so my guess is a leak.. does anybody know how much of a job this is? I’m no mechanic by any means. Labour and parts estimate? Always something with these M8s haha. Thanks for everyone’s input it’s appreciated. Going to the mechanics next week to a get a full overlook.
