Second disc brake for front end
Thoughts, comments, suggestions, testimonials?!?!?
There's a CVO package however I think that lists factory parts for it.
I believe he used Performance Machine slider/calipers/rotors.
I think he used an Ultima wheel with the 2-nd rotor
ready hub... I'll see if I can find his thread...
EDITED AGAIN: The forum member is ThunderTruck and
it appears he did not create a single "upgrade" type thread for it.
He posted most of his progress/pictures in the "What did you do to your Softail" thread...
EDIT: now if you want to "roll your own" or DIY so-to-speak.
What you can do is use the front-end components from the Touring models
since they had dual-disc frontends. You'd need the 41mm sliders, calipers,
wheel.
In either case, (aftermarket parts or HD parts), you will need a Master Cylinder.
T.
this "What did you do to your Softail thread" starting about here:
https://www.hdforums.com/forum/softa...l#post20332026
hth,
T.
The conversion was night and day for braking. I took the more expensive bling route but you could use Harley components.
If money and effort look like theyre gonna be too great. You could also go to a floating rotor upfront, and a four piston caliper for probably half the money or less. It might not be as good as dual caliper, but it certainly would be better than it is.
a 4-pistion caliper from the XR1200 and a "contour" floating rotor from EBC.
T.
