Seat Removal Help!
Old Jan 2, 2006 | 04:37 PM
Anniesage's Avatar
Anniesage
Default Seat Removal Help!
I must be doing something wrong - am trying to get the seat off my 06 Heritage Classic - and I can't get it to budge. Is there some sort of trick to removing it? I undid the thumbscrews on either side of the seat and also the one behind the passenger seat. And I can't get it to budge in any direction. It is as if something else needs to be undone? I have looked at the manual and it too says to loosen the three thumbscrews. But it ain't working for me. What am I missing or what am I doing wrong? Any insight or guidance would be appreciated since I have been out in that cold damp garage for nearly 45 minutes and am starting to freeze my S#@!^% !!
Old Jan 2, 2006 | 05:10 PM
Rhubarb's Avatar
Rhubarb
Default RE: Seat Removal Help!
Mine came off by loosening the one out of the passenger seat, then removing it.
Then loosening the 2 out of the rider seat and lifting from the back.
Do you maybe have a grab strap attached to the bike still? Mine is part of the seat so I don't have to pull it.
Old Jan 2, 2006 | 05:12 PM
Anniesage's Avatar
Anniesage
the strap slides off the passenger, but is attached separately. I did what you just said Rhubarb - but it isn't budging!
Old Jan 2, 2006 | 05:29 PM
Rhubarb's Avatar
Rhubarb
My next step isn't really advised just usually how I handle things...
Pull harder, then kick it if it doesn't come off.
If the kicking doesn't work, swear a lot and throw something.
Sorry I couldn't be of more help.
Old Jan 2, 2006 | 06:02 PM
2005FATBOY's Avatar
2005FATBOY
this might help on one side where the screw fastens to the frame , take a small screwdriver and between the frame mount and the seat mount just give it a little twist it should pop one side off then the other side will come off very easy
Old Jan 2, 2006 | 06:56 PM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Annie,
I just helped my friend remove the seat off his heritage too. It threw me for a minute becaue on my bagger all you have is the screw on the rear fender.
Here's what I found: The two allen screws on each side of the rider seat seems to have a spring or clip holding them to the seat bracket. Even when you loosen them all the way a part of a thread still entends into the frame making it impossible to pull the seat off. After removing the rear screw on the fender and loosening the two allen bolts under each side of the seat, lean over the seat and pull out on the two bolts and then lift up. Let me know if this helps.
[sm=biker2.gif]
Old Jan 2, 2006 | 08:38 PM
Anniesage's Avatar
Anniesage
thanks terry - I DID need the extra information! So where do I send the check? Any thoughts, though, as to why they couldn't make the seat like the RoadKing - undo screws and remove?
Old Jan 2, 2006 | 08:53 PM
Terry TK's Avatar
Terry TK
Glad I could help you Annie.
Terry
mean green
Apr 22, 2024 12:38 AM
Candubrain
2014-2024 Touring Models
Apr 9, 2017 08:02 PM
Scorpio49
Feb 19, 2013 10:27 AM
flyburch
May 13, 2008 04:35 PM
