Riser bushings
Old Jan 16, 2010 | 10:13 PM
flynhigh56's Avatar
flynhigh56
I would go ahead and change them out while you have it most of the way there anyway just changing out the bars. I ended up going with 16" apes but I was going to do it even when I was originally going with 12 1/2". They are not that expensive and gives you a more solid feel. Just my opinion.
Old Jan 17, 2010 | 09:44 AM
myfhfb06's Avatar
myfhfb06
Originally Posted by fatheadonsoftail
Yeah with my 12.5's I feel no differance in movement from the stock bars.
I have the bushings but can any one tell what is involved with changing them, like how hard they come out or go in or any special precautions I need to know about it.
I was gonna do it when I did my bars but I only had the weekend to get it done at the time and that included the exhaust and when looking at them I wasn't sure what was involved so I skipped it at the time.
Seems like a good reason to go out in the garage and play with the bike!
It's really easy to remove them. Just remove the bars and risers and the bushing are easily accessible. Use a screw driver to knock out the bottom bushing and from what I remember the top bushing comes out pretty easy.
Old Jan 17, 2010 | 11:32 AM
aviator's Avatar
aviator
since the original post is over 2 yrs old, I bet he's got them on and probably worn out by now.......
Old Jan 17, 2010 | 08:37 PM
fatheadonsoftail's Avatar
fatheadonsoftail
Actually not
I just did all the mods in June and rode the rest of the summer which here ends in October early
Old Jan 17, 2010 | 09:54 PM
klf33's Avatar
klf33
Originally Posted by bensonjv
I put 12.5" Wild1 Chubby apes on my Springer. Initially I just had the OEM bushings. Lots of slop and movement - which is what the bushings are deigned to do; absord vibration and provide some softness to the bars. But it was overkill, especially with apes. I put (Springer specific) poly bushings in and it tightened things up a lot. I can't say I noticed any added vibration. A local indy recommended I tighten them a little tighter than the spec torque. That helped firm things up even more.
If you are going to have the front end apart, I'd highly recommend you do the bushing swap. Its worth the extra couple bucks.
+1 same thing for my 12" Road6 Custom apes.
Old Jan 17, 2010 | 10:16 PM
JohnnyBravo's Avatar
JohnnyBravo
Originally Posted by JohnnyBravo
is there such a thing as solid bushings.....i just put my bike in the shop today to install 10" minis with 3 1/2" risers.....the guy showed me new bushings but, they looked like they were metal.....I'm not sure now as it was on a table of misc parts neccesary for the change.....brake lines, braided cables, bushings, bars, risers, etc,
well to answer my own question....there are solid bushings. They seem just fine as far as vibration. they do vibrate a bit, but whats a harley without a little vibration! there is no movement with my apes and there wont be...works for me!!!
Fallenares
May 19, 2014 02:15 PM
whovoy580
Sep 23, 2011 09:42 PM
deadeye
Nov 14, 2010 01:14 PM
07bobber
Oct 25, 2007 12:00 PM
Uncle D
Sep 17, 2007 09:25 PM
