front turn signal relocation
Old Feb 8, 2006 | 01:33 PM
flstfjeff's Avatar
flstfjeff
Default front turn signal relocation
I would like to relocate front turn signals on my '05 Fatboy.Do not want passing lamps,would'nt mind a small bar mounted under headlight to mount turn signals.I want to keep Harley bullit signals,anyone else figured out this problem?Part numbers,manufactor,pictures would be great.Thanks
Old Feb 8, 2006 | 03:34 PM
AK_Hog_Herder's Avatar
AK_Hog_Herder
Default RE: front turn signal relocation
If you have the money.
Check Headwinds.
Be advised they are almost as proud of their stuff as the MOCO.
Old Feb 8, 2006 | 06:26 PM
flstfjeff's Avatar
flstfjeff
Thanks,yes they are proud of their stuff.I will e-mail and ask them concerning the under fork cover/bracket pertaining to the size of the mounting holes in the bracket.Being billit aluminium and chromed,at 142$,that is steep,but that mount would sure look sharp.Any ideas of mounting a hollow stemmed bracket to side of headlight covers and running wires through the hollow bracket to the turn signals?
Old Feb 8, 2006 | 09:34 PM
gevange's Avatar
gevange
I used 2 5/16x24 studs, loctite,and 4 5/16x24 nuts in lower bolt holes on tin side plates.
Old Feb 9, 2006 | 07:34 PM
ingenue's Avatar
ingenue
Jeff,
Just saw this - Bubba's Bike Accessories. Is this what you're looking for?
Old Feb 9, 2006 | 07:49 PM
liltrk's Avatar
liltrk
I have a kit, p/n 58270-02 which is used to mount the fatboy windshield. It consists of two chrome bars which mount on the outside of the fork tins. There is a hole in the bottom which, IF you don't have a windshield, might be good for the signals. Mine had passing lamps so it was easy, but you might have a look at this kit at the stealership.
Old Feb 9, 2006 | 11:51 PM
rountree's Avatar
rountree
I just bought a relocation kit for my Deuce from Harley for about $45. I don't think it will work on a Fat Boy but seems like I did notice a reference to a part number for a Fat Boy. Try you Harley dealer. I'll try and find the part number tomorrow.
Old Feb 10, 2006 | 09:05 PM
ultravista's Avatar
ultravista
I bought the relocation kit which mounted to the tubes. To hide the wiring, I ground a U into the chrome cover to run the wires inside and out to the harness on the right side of the bike. You can only see the wires right at the light itself.
Old Feb 11, 2006 | 12:58 AM
haksaw's Avatar
haksaw
unfortunately it looks like most of the answers deal with forks without the tins. Your really limited with the tins on there. I guess you could consider mirror signals like kuryakyn makes.
good luck
jrogerb144
May 20, 2018 10:03 AM
PistolPete83
Dyna Parts
Feb 5, 2013 11:04 AM
CRZYLGZZ
May 17, 2010 05:24 AM
Radalack17
Jan 29, 2009 12:43 PM
