Another Handlebar Internal Wiring Question
Old Jul 14, 2008 | 02:58 PM
jkworrell's Avatar
jkworrell
Stage IV
Default Another Handlebar Internal Wiring Question
I have some wild1 wo504's I'm going to install on my 2006 fatboy.&nbsp\\;\\\\\\; The internal wiring of the hand controls seems pretty straight forward, but I'm a little unsure of the best way to get the turn signal wires inside the bars.&nbsp\\;\\\\\\; Do I need to drill holes in the bottom of the hand controls housing&nbsp\\;to get the wires inside?
&nbsp\\;\\\\\\;
Any ideas or sugestions would be appreciated.
Old Jul 14, 2008 | 06:05 PM
renoa18's Avatar
renoa18
Default RE: Another Handlebar Internal Wiring Question
No you should beable to stuff them in the hole provided for the other wires.&nbsp\\; It is a tight fit and I found the best way to do it is tape all the wires to a coat hanger and push it through. good luck
Old Jul 15, 2008 | 08:49 PM
jkworrell's Avatar
jkworrell
Stage IV
Hey appreciate the tip using the coat hanger.&nbsp\\;\\\\\\; I thnk the wires will fit just fine in the hole in the handlebars but the hole in the handlebars is covered up by the controls housing.&nbsp\\;\\\\\\;How is the best way to get the wires from the turn signals (which are on the outside of the housing) inside the housing so I can put them inside the handlebars?&nbsp\\;\\\\\\; The stock handlebars were dimpled on the underside and would allow enough room to run the wires underneath.&nbsp\\;\\\\\\; The wo504 bars are not dimpled.
Old Jul 16, 2008 | 05:47 PM
squirrelu's Avatar
squirrelu
do it the old school way and take the ture signals off u don't need them
Old Jul 16, 2008 | 07:11 PM
Agentorange's Avatar
Agentorange
I agree with squirrel. Take them off (unless your state requires them) it cleans up the bars.
buellrider76
Aug 18, 2015 02:38 PM
kvb78
Dec 11, 2011 12:34 PM
Zinje
May 10, 2009 11:59 PM
plumblocal1
Jul 10, 2008 10:18 PM
baxter
Apr 23, 2007 07:48 PM
