"DYNO" Numbers For SOFTAILS
Old Apr 9, 2014 | 11:39 AM
  #981
Prw3's Avatar
Prw3
Originally Posted by DigbyHD
Could anyone take a quick look at my graph for me, only thing i see is the HP and Tq dont cross over at the perfect RPM but is close
thanks
HP and TQ won't cross over on a Vtwin.... looks like your ideal HP/TQ RPM is approx 3500 RPM....pretty typical for a Harley.
Old Apr 9, 2014 | 12:03 PM
  #982
DigbyHD's Avatar
DigbyHD
Thanks man, just wanted someone elses opinion.
Old Apr 9, 2014 | 12:07 PM
  #983
Prw3's Avatar
Prw3
No worries...on really high RPM motors usually not found in a harley frame....TQ can build faster with HP catching up with RPM...usually not typically in a tractor like harley motor or at least what Ive seen.
Old Apr 9, 2014 | 12:15 PM
  #984
ghoticov's Avatar
ghoticov
Originally Posted by ghoticov
Just got my bike back from the dyno. I am floored at the results. It pulls sooooo friggin hard. Also, no compression releases... just using the 574 easy start crane cams and they work like a charm.
107" cylinders
No Headwork
574 Easy Start Crane Cams (Chris "Rocket" Rivas endorsed cams)
CP Pistons (10.75:1)
Big Sucker (extended filter)
Big Shot Staggered
PC111
I have an opportunity to buy a Pro Pipe 2:1 at a VERY good price so I am thinking about jumping on it. Do you guys think going with the Pro Pipe will get rid of that dip in my torque curve above?
Also, is it necessary to get the bike retuned after putting the new pipe on or could I wait a little while to do it?
Old Apr 9, 2014 | 12:31 PM
  #985
spelk3's Avatar
spelk3
thanks
Horsepower is calculated from torque.
HP = TQ x rpm/5252; the lines should cross at 5252 rpm.
Old Apr 9, 2014 | 03:08 PM
  #986
DigbyHD's Avatar
DigbyHD
yes so mine is about 500 rpm off right?
Is that bad?
Old Apr 10, 2014 | 07:12 AM
  #987
imrotton2's Avatar
imrotton2
thanks
the tq scale is set to 100 ft lbs , and the hp scale is set at 90 hp... thats why they dont cross at 5250rpm...looks like they were trying to make the tune appear better...jmo
Old Apr 10, 2014 | 09:18 AM
  #988
DigbyHD's Avatar
DigbyHD
Thanks for taking a look.
I didnt see that before, so they do cross at 5250 but he spread out the 2.
IDK why he did that, maybe to see it better??
But in your opinion does it seem pretty typical for my set up? seems like i got a little bit more than most guys do, probably due to going with the pro pipe and not a 2into2.
Next year i may do some cams.
Old Apr 10, 2014 | 09:22 AM
  #989
Prw3's Avatar
Prw3
The TQ and HP aren't set to anything, the software program adjusts the frame based on creating a relevant graph showing the peak HP and TQ....no reason to expand the graph to show if the TQ and HP cross. Why such concern on where they intersect?
Old Apr 10, 2014 | 03:46 PM
  #990
DigbyHD's Avatar
DigbyHD
Im not concerned at all lol.
So the comment on him setting the TQ to 100 and the HP to 90 is not relevant?
