heel-to-toe shift
Old Oct 15, 2008 | 12:19 AM
  #31
tk353's Avatar
tk353
I use the front only when i wear summer boots and the heal and toe when i wear longer and taller winter boots. with short boots my pants leg rises.
Old Oct 15, 2008 | 02:09 AM
  #32
Lowbro's Avatar
Lowbro
Originally Posted by pococj
Then where is the suicide clutch and jockey shift?
Now those were the days ! wish I had suicide clutch scoot !
Old Oct 15, 2008 | 06:19 AM
  #33
pococj's Avatar
pococj
LaBriola.
Old Oct 15, 2008 | 09:12 PM
  #34
TexFordD's Avatar
TexFordD
Karvorkian (sc) makes a spacer to eliminate the heel shifter by filling the gap.
Under $40 and the best (and cheapest I may add) mod I've made so far.
Old Oct 15, 2008 | 10:12 PM
  #35
trafficjams's Avatar
trafficjams
The forum should have a damn sticky on this heel/toe shifter issue!
Folks... there are aftermarket extension shift levers available... up to 2" over stock.
http://www.phatperformanceparts.com/...de=SB-SHIFT-HD
I think Wicked Image has more customized billet levers that are also longer than stock.
Old Oct 15, 2008 | 10:16 PM
  #36
swwilson77's Avatar
swwilson77
Cool
Old Oct 15, 2008 | 10:35 PM
  #37
emwolb's Avatar
emwolb
yeah, on my streetglide i removed the rear one immediately, and there is a cool little chrome thing that harley has in their parts and accessories catalog that's about twenty bux and it attatches with an allen set screw. that way if you want to return to stock, you can. i agree, size fourteen boots just don't work well with the two shifters. also if you can't reach a happy medium with the splines, you can always adjust the shifter rod that attatches from the shifter bellcrank to the transmission lever. it's threaded too.
Lone Dawg
Apr 3, 2019 04:55 PM
Frank the Real Biker
Jun 4, 2017 05:51 PM
Fatboy1389
Oct 11, 2015 09:32 PM
PURK
46
Jun 18, 2010 09:58 PM
mayfly
May 1, 2009 12:28 PM
