FXSTI / FXSTC Front wheel
Old Nov 13, 2008 | 02:38 PM
eddyp's Avatar
eddyp
Default FXSTI / FXSTC Front wheel
Hi,
Im in the process of fitting a 2007 FXSTC profile wheel to my 2006 FXSTI, I know I will have to change the bearings on the wheel to 3/4" but does anyone know the spacer sizes I will need, I think the hub on the FXSTC may be slightly narrower. Any help would be appreciated.
Old Nov 13, 2008 | 04:34 PM
Roadjunkie1's Avatar
Roadjunkie1
some folks like them and some folks dont
Old Nov 14, 2008 | 01:50 PM
eddyp's Avatar
eddyp
Bit like Chicargo then!
Old Nov 14, 2008 | 04:37 PM
mojojones's Avatar
mojojones
spacers are the same on both years
Old Nov 28, 2008 | 09:35 AM
eddyp's Avatar
eddyp
Well I managed to get the new wheel fitted by swapping the bearings on the wheel to 3/4 bearings. The spacers were infact different although the Harley parts book said they were the same.
The 3/4 bearings sit slightly proud so I was able to use the 2006 spacers. 1" bearings sit flush and would need 2007 bearings.
Anyway when I took my 2006 wheel off and removed the tyre I found that there was a substantial amount of rust on the inside of the rim and underneath the tape. I think if I hadnt found this it could have caused a punture in the near future.
My bike had never seen rain, is well looked after and kept covered in a garage....the rim should not be rusty after 2000 miles and 23 months old. Anyone who is changing tyres soon should have a close look inside around the tape...just in case
Old Nov 29, 2008 | 06:12 AM
Korbenw7p3c's Avatar
Korbenw7p3c
Default rust...
...that figures, as I wash my dang bike so much that it's bound to have rust in the front rim if I were to ever take off the rim tape. I do use high velocity air dryer after every washing.
Old Nov 29, 2008 | 09:02 AM
rbabos's Avatar
rbabos
The front rim on an 07 fxstc is chromed aluminum, not steel. Can't figure out where you got the rust from?
Ron
Old Nov 30, 2008 | 12:13 PM
eddyp's Avatar
eddyp
rbabos, it was the 2006 wheel with the rust
jqb12
Wheels/Tires
Mar 28, 2017 04:42 PM
texashillcountry
EVO
20
Feb 11, 2015 03:12 PM
riderboy1961
Wheels/Tires
Jan 30, 2014 05:01 PM
WRAITH
May 4, 2010 06:45 AM
scaryonly
Wheels/Tires
Dec 3, 2009 12:15 PM
