Does anyone know of replacement shocks for Fat guys? I'm pusing 270lbs and am wondering if there are better shocks for my NT. Some bumps are a pain in the A$$.
If you are "Feeling it Bottom out"... You need to get your pre-load adjusted for your, errr, ummmm.... Girth, yeah, that's it, Girth.....
If you have the time, patience and access to a few specialty tools, I'd tell you to get underneath that bike, shorten those shocks, and increase the preload....
Or, take it to a shop and have them bitch about having to do it.... No tech likes to adjust a Softail suspension.... PITA!!!!!!!
From my experience do not use the progressive. I had two pairs wind up leaking and sent them both back and stayed with stock with preload adjusted correct I am 290 on a 2003 heritage. I did see that someone is selling softail shocks for "big guys" I will look for the ad....
They are works shocks - I have limited info from their web site:
Adjustable length shocks for 2000-on Softails in polished 7075-T6 billet aluminum with chromed steel components. Feature internal springs for a clean smooth look. Adjustable length posts that can be adjusted without removing the shocks. Available in standard and new heavy versions. Let me know if anyone wants more info
I can see you've changed your exhaust a couple of times , can't tell from your pictures how it is mounted . If it is mouted on the lowest part of your frame directly under the swingarm pivot make sure the mounting bolts do not protrude beyond the threads , has great potential to make bottom out prematurely .
10-4 on changing the exhaust. And I'm not done. I'm putting on a new set next week !!
Thanks for the info on the mounting bolts. I check this afternoon and they look good....
I think I just might be asking for too much, I was talking to another Softail owner and says his is a little hard on the bum when you hit holes and such.
