Gas tank question
Old Apr 29, 2009 | 12:00 PM
nosinjcted's Avatar
nosinjcted
Default Gas tank question
Ok this might be a dumb question but I'm curious, this is my first harley, I've had it for about 3 years. I have an 88 Softail, the gas tank is 2 piece's with a hose connecting them on the bottom and top. When I fill it up, it'll fill up reall fast then the gas level will go down real slow. I'm guessing it fill's the side then flow's to the other, but it take's a long time. I'll have to sit there and wait more then 10 minutes or so. Is this normal? Or is there a vent that's clogged or something? The nipple on the bottom is real small so I figured it would take a while, but it seem's like something is wrong. Any advice?
Old Apr 29, 2009 | 12:20 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Newer bikes only have one gas cap on the right side with the phony one on the left for the gas gauge.
But a lot of the older ones had two gas caps, one for each side.
If it does try filling it on the left (low side when on the kick or jiffy stand) first, then topping it off on the right.
If not maybe one of the crossover lines is clogged up cause ten minutes seems awful long to me.
PS there is no such thing as a dumb question, unless its the one you didn't ask.
Cause the answer to that one is probably the one that will save you from making a big, expensive, and or painful mistake.
Old Apr 29, 2009 | 12:35 PM
nosinjcted's Avatar
nosinjcted
I do have a cover on the left side, but it is extremely tight as in it won't budge at all. I was told not to try to get it off cause it probaly wont go back on. So I havent tried. Should I try to get it off? Should it just screw off like the right side? I had the tank off this winter and blew out all the lines, it doesn't seem as if they are clogged. I took the bike out the other day, and i'm sick of waiting at the pump.
Old Apr 29, 2009 | 01:50 PM
Harley_Dude's Avatar
Harley_Dude
It turns in the opposite direction.
Old Apr 29, 2009 | 01:56 PM
Dorkman's Avatar
Dorkman
Not sure what kind of vent your model year has, but with both caps off you should have no trouble filling the tank. It's likely that without the left cap off there is nowhere for the air to escape while filling.
Old Apr 29, 2009 | 02:10 PM
nosinjcted's Avatar
nosinjcted
hahahha, that would be my luck. I'm pretty sure i've tried turning it both way's though. I wanna leave work now and go take a look at it.
I figured it wasn't able to vent properly, so do people normally pop off both cap's to fill up?
Old Apr 29, 2009 | 08:27 PM
Dorkman's Avatar
Dorkman
I figured it wasn't able to vent properly, so do people normally pop off both cap's to fill up?[/quote]
With a two cap system and a vent problem they probably do.
Old Apr 29, 2009 | 09:45 PM
oct1949's Avatar
oct1949
might try to ask in the Fuel, engine Tech section, and see if u get your answer.
there has to be a vent somewhere, either hose or cap if filled from one side
Old Apr 29, 2009 | 11:52 PM
I8SMK4U's Avatar
I8SMK4U
Split tanks have gas caps that turn opposite. The left tank turns off to the Right, I promise.
1. So how long did it take you at the pumps to fill both tanks up?
2. Did it come off.
Old Apr 30, 2009 | 12:29 AM
My bad, I totaly forgot the tanks had left and right hand threads on them.
FatKen
May 5, 2016 10:10 PM
BlackTez
Dec 20, 2013 04:20 PM
cstolp
Aug 15, 2007 07:33 AM
shengte
Jul 20, 2007 08:55 PM
99FXST
Exhaust System Topics
Feb 17, 2006 10:14 PM
