Softail Custom vs. Wide Glide
Old Sep 20, 2009 | 05:35 PM
ThreatLevel Midnight's Avatar
Default Softail Custom vs. Wide Glide
I know one's a softail and one's a dyna, I know one's counterbalanced and the other is rubber mounted...
What I'm looking for is advantages/disadvantages/thoughts/opinions/issues that are less obvious. I also know I have to ride each one and compare for myself....just asking for your .02 here.
Old Sep 20, 2009 | 05:49 PM
Mr. Lucky's Avatar
Mr. Lucky
If you are a good enough rider to take advantage of it, the Dyna is the better handling of the two. There is much more aftermarket parts availability for the Softail though.
Old Sep 20, 2009 | 06:07 PM
Chazmanian's Avatar
Chazmanian
R.I.P. BROTHER
You gotta ride em' both.
One shakes at stoplights the other dosent.
You can see the shocks on one...cant see em' on the other.
One has gobs of aftermarket parts is wholly interchangeable with the other bikes in its lineup...The other? Not so much.
One handles a little better than the other.
Ride em. The "One" will itself be known!!
Old Sep 20, 2009 | 08:05 PM
Wallaby's Avatar
Wallaby
A few more subtle differences also,
06 onwards Wide Glides have 49mm forks Vs. 41mm for the Train.
06 onwards Wide Glides have more rake, 34 Vs. 32.
06 onwards Night Trains have a wider rear wheel/tire, 200m Vs. 160mm.
The TC 'A' motor in the Wide Glide will rev out a little faster than the TC 'B' motor also as the balanced 'B' motor has counterbalances (to quell vibrations) that add weight to the flywheel effect, if thats important, isn't to me.
I like Softails personally, but no-one cares but me.....
Old Sep 20, 2009 | 11:50 PM
Trey Hogger's Avatar
Trey Hogger
I had an 04 Dyna Wide Glide. It handled really well as long as I kept the front tire inflated properly. (o: Compared to to the 09 Softail Custom, the WG seemed quicker, with surprisingly strong acceleration, (even tho a TC88) whereas the Softail feels kind of draggy and has a ragged sound to it when I accelerate hard. I think that is reflective of the A vs. B motors, or maybe different gearing? The Softail with the wider rear tire does seem more stable on the freeway over rough or grooved pavement - the WG was wild at times. Style-wise, the Custom presents a different visual than the Dyna, something I like better.
Jan 15, 2022 08:49 AM
murat3425
Mar 4, 2017 10:47 AM
Tedjay
Sep 23, 2012 10:10 PM
hotroddarin63
Feb 26, 2011 07:09 PM
mgellar
Oct 21, 2006 09:39 AM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
