rear wheel on fxst?
Old Jan 14, 2010 | 08:43 AM
Superslick's Avatar
Superslick
Default rear wheel on fxst?
does anyone know if an 18x3.5 wheel with 160 tire fit under a stock 02 fsxt without doing mods?
Old Jan 14, 2010 | 09:49 AM
OTTO's Avatar
OTTO
Default Wheel
Hi i dont think it will . If you check with the dealer they can help with this. I thinlk it will rub.
Old Jan 14, 2010 | 10:55 AM
Superslick's Avatar
Superslick
thx for the help!
Old Jan 14, 2010 | 11:19 AM
miketedesco's Avatar
miketedesco
Dont bother with the dealer. They wont be helpful on this one.
With not mods....no the tire wont fit.
With minor mods, yes the tire will fit under your stock fender.
Back in 02 they were still using the old hardware inside the fender to hold the struts on which was much bulkier. If you replace that hardware with the new style hardware, then you have room inside your fender for a 150 with no other mods what so ever (to my knowledge). To go to a 160, you need to center the tire in the fender. To do this, do some searching. I have posted info on this quite a few times. Its basically just using a 1/8" wider spacer on the right side of your wheel and a little bit of grinding on your brake caliper. Overall pretty easy. I am running a 160 on my 04 and plan on squeezing a 170 in there next time.
Old Jan 14, 2010 | 11:43 AM
Superslick's Avatar
Superslick
i heard some talk about turning the strut bolts around and running them from inside out or is there actual peices under the fender to be replaced?
btw thanks for the info!
Old Jan 14, 2010 | 11:47 AM
miketedesco
Its just the strut bolts. The easy solution is to turn them around and use accorn nuts or something simular. The best way would to be to just buy a set of 03-05 hardware. It cant be more than $15 or $20 for the 4 nuts and bolts. You may only need the nuts for the inside anyway.
If you have any more questions don't hesitate to ask.
Old Jan 14, 2010 | 11:51 AM
Superslick's Avatar
Superslick
one more question should i go with a lower profile tire or u think it would matter?
Old Jan 14, 2010 | 12:06 PM
djcustom1's Avatar
djcustom1
Default rear wheel
No i dont think it will. Afrind of mine tried it on an 03 and it was to big.
Old Jan 15, 2010 | 08:54 AM
miketedesco
I am not sure the exact size it is (I cant really go out in my garage and look since I am in Iraq...), but the stock 150 will fit without issues. The 160 you would run is the tire that comes stock on a Deuce. If you do some searching, or use Metzler tires website that will give you the original equipment sizes. Don't forget, Metz tires run narrow, so a metz 160 is more like a dunlop 150.
I think the Deuce 160 is the same height, just wider. Since it is on a 17" wheel it will be a lower profile tire though.
tech7734
Feb 16, 2019 05:21 PM
RealDealHog
Jun 2, 2016 10:32 AM
Desertdog7
Feb 6, 2010 12:00 AM
Double00Aught
Apr 1, 2009 10:07 PM
Bobberino
Feb 23, 2008 06:16 PM
