Cam Chain Tensioners
Old Feb 3, 2010 | 05:49 PM
JonnyDeluxe's Avatar
JonnyDeluxe
Default Cam Chain Tensioners
I'm about to have the 95 inch conversion done on my '05 Deluxe. This is a good time to get rid of my cam chain tensioners, but am undecided as to whether I should go with gear driven or hydraulic. I'm sure I'm not the first guy here to have this question - what's the general opinion? Advantages to one or the other, any reasons to go with one over the other? I don't want to spend a fortune, but at the same time want this to be done as right as it can be....any of your thoughts or experiences are appreciated!
Old Feb 3, 2010 | 08:51 PM
oct1949's Avatar
oct1949
having an 07 I've read most post in here on the new Hyd system and it seems to be doing great. Some are predicting they'll go easy 100k.
Still if U go with gears make sure Ur crank run out is within the limits, then U'll never have to wonder or worry about the tensioners at all...
If Ur doing a BB Ur probably doing cams anyway. I am not sure, but I think U'd save money by going with gear cams (I've never priced them) rather than getting new cams and then also do the Hyd system kit for the tensioners also. Should be fairly easy to price parts and see.
If U stay with the cams U have now, then the savings might be with going the Hyd kit and take the worry out..
Old Feb 3, 2010 | 09:02 PM
hpfatboy's Avatar
hpfatboy
Thumbs up
Go GEAR DRIVE and be done with it! No more second guessing!
Old Feb 3, 2010 | 09:22 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Make sure to measure crank run out if you are doing gear drives. I hear you get more pwoer from gears but i replaced my stock tensioner shoes in my 02 at 40k. They were not nearly worn all the way, but i was glad I did it. I figure at 65k I'll have another look to see how they are looking. A good friend checked his hydraulic tensioner at 38K and had no wear at all.
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Make sure to measure crank run out if you are doing gear drives. I hear you get more power from gears but i replaced my stock tensioner shoes in my 02 at 40k. They were not nearly worn all the way, but i was glad I did it. I figure at 65k I'll have another look to see how they are looking. A good friend checked his hydraulic tensioner at 38K and had no wear at all.
Old Feb 3, 2010 | 10:11 PM
Mike NY's Avatar
Mike NY
I did my 95" and Cam upgrade last Winter. Went with the new Hydraulic Tensioners and Andrews Conversion 37N Cams. I considered Gears but didn't want to deal with some of the potential issues like Crank-Runout and Noise (whinning). So far so good but I haven't put too many miles on since last Winter, maybe a few thousand.
Mike
NY
Old Feb 4, 2010 | 03:20 AM
hpfatboy's Avatar
hpfatboy
Thumbs up
Quote Mike NY: I considered Gears but didn't want to deal with some of the potential issues like Crank-Runout and Noise (whining). There is a little noise, but at least no WORRIES or SURPRISES. What's the use of quiet when you have a TICKING TIME BOMB IN YOUR CAM CHEST! Give me a little noise anyday, with PEACE OF MIND!
Old Feb 4, 2010 | 03:51 AM
BoomerBob's Avatar
BoomerBob
If you had a pre-2003 I'd say go with gears if the runout is ok. Otherwise I'd go with the Andrew Hydro kit with the upgraded oil pump with 20% more scavenging. The crank quality went way down after 2002.
The HD kit leaves the silent chain on one of the cams I think whereas the Andrews kit uses the newer roller chains.
Old Feb 4, 2010 | 11:33 AM
02heritage's Avatar
02heritage
Default Chain or gear
I had the tensioners replaced in my bike at 50K. Decided to stay with the springs, I was unaware of the upgrade kit to hydraulics at that time. If you decide to go with the gears you definately get the crank runout checked.
Quiet Thunder
Nov 27, 2016 12:12 PM
FXD_noob
Mar 19, 2013 11:28 PM
azharleyrider86401
Mar 29, 2011 06:03 PM
electra glide
Exhaust System Topics
Dec 31, 2008 09:48 AM
pauletich
Apr 12, 2008 04:41 PM
