Removing shocks
Old Dec 18, 2011 | 11:02 AM
  #31
drspencer's Avatar
drspencer
Originally Posted by jreichart
Oh, it's also helpful to have a small bottle jack or car jack to place under the rear tire so you can move it up and down to get the new shocks lined up with all the bolt holes.
So, I take it it would be easier with the rear wheel on?
I ask because I'm sending my rear rim out for chroming.
Should I swap the shocks before or after I remove the rear wheel?
Thanks again
Old Dec 18, 2011 | 11:44 AM
  #32
jreichart's Avatar
jreichart
It can be done either way, you just won't need the jack to move the swing arm if the wheel is removed.
Old Aug 16, 2015 | 02:37 AM
  #33
ThaiTony's Avatar
ThaiTony
I may be posting this prematurely. but I've had an idea and it seems I am not the only suffering frustration with this one bolt (right side, rear shock bolt). Unfortunately I wont be able to try this for a couple of days (when I can get my hands on one). But I've had an idea and if it does work may be the answer.....
Now I don't know what they are called in the States but we used to call it a "paddock stand". It MAY support the bike high enough and give enough clearance to get enough force to move the bolt.
I'll get back after Monday and let you all know how it went.
GOOD LUCK!!!
Old Aug 16, 2015 | 04:03 AM
  #34
ThaiTony's Avatar
ThaiTony
A Paddock stand
This may work, It shouldn't hurt anyway.....
Old Aug 16, 2015 | 04:41 AM
  #35
piperbob's Avatar
piperbob
When I did my shocks, I used the weight of the bike to loosen the bolts.
Bob
1997 Heritage
Eunoterpsia
Nov 2, 2015 06:38 PM
Crashone
EVO
28
Apr 7, 2015 08:08 PM
Rocker NH
Sep 7, 2012 06:06 AM
plane
Sep 26, 2009 11:33 PM
07bobber
Mar 29, 2008 11:18 AM
