Combination Digital Speedometer/Analog Tachometer
Old Jul 29, 2010 | 11:20 AM
  #31
dusty2221's Avatar
dusty2221
I wish this were available for my 0ld3!
Old Jul 30, 2010 | 07:24 AM
  #32
jjjefferson's Avatar
jjjefferson
4th Gear
Default Ride Report
Originally Posted by jjjefferson
I ordered the 74717-10 from Chicago HD for $239. I gave them the milage that I guessed I would be at by the time it arrived. My guess came within 10 miles. (Good thing it rained for a solid week, LOL)
CHD got it from Harley in 10 (business) days, then 2 (business) days to ship. Calendar days 19... ordered on July 9th. Recieved July 28th.
Install was about 15 minutes....the rubber o-ring slowed me down...put a little hand soap on it and the new speedo slid right in.
I run a Thundermax w/ Autotune so I "re-initialized" it after install since I pulled the ECM fuse and disco'ed the battery.
Reconnected everything and she lit right up. After a quick check of the lights and signals... I fired it up.
The Tacho jumped and settled just under the 1000 RPM mark. Which is correct since I know the TMax is set to idle at 960. Speedo has a Clock, Trip A, Trip B, ODO and "RANGE - Miles to Empty." Engine and security lights function as designed.
I was pleasantly surprised to see the "Range" actually working. Since installing the TMax on the "stock" speedo....range vanished.
I only drove for a few miles but all seemed good. Will put some more miles on it this weekend and update.
JJ
Took the new speedo for a 40 mile ride this AM. One previous poster asked if this speedo had the 6th Gear Indicator. Answer is YES. Very bright big number 6. Bottom row second from the left. This speedo is BRIGHT! Left the house at 0530 hours and it was still dark...this thing lit up like beacon. While it is bright it is "easy" on the eyes....nice warm red light. Easy to see the LED speed too. The Tach is well lit too....multiple red backlights in there around the bezel.
One thing I did notice is that the speedo is off by minus 2-3 mph between 60 - 70 mph. So when it says 60 you are doing 62-63. I was comparing it to my Garmin Zumo 450 which was perfectly in-sync with my OEM "stock" speedo. Since I run a Thundermax ECM I may be able to adjust it. Will look into that.
Other than that...I am very happy with this speedo.
Old Jul 31, 2010 | 07:33 PM
  #33
jjjefferson
4th Gear
Emailed Zippers Support with the speedo calibration question. They sent me a nice little calculator for tweaking the speedo cal number. Simply put in the original number 42450 (for 07 Softails and up), the MPH reading on the speedo, the MPH reading from another source ie my GPS. Then it calculates a new value...for my 08 FXSTC running the 74714-10 the new number is 41508. Now the speedo is dead on accurate!
JJ
Old Aug 1, 2010 | 11:28 AM
  #34
Softy 103's Avatar
Softy 103
Originally Posted by jslamerman
I was wanting to purchase this for my 2007 (plan to do so even though), couldnt figure out why my softail wasnt listed as an application, it still plugs in, just has the added feature of fuel/mileage remaining...........we will see I guess. Dealer and I went through as much wiring as we could think of, and examined plugs.......SHOULD work.......(famous last words)
So jslamerman6471741, did that new digital speedo and tach work on your 07 softail?
Old Sep 4, 2010 | 07:48 PM
  #35
Softy 103's Avatar
Softy 103
Just wanted to let people know that I put the new digital speedo and tach on my 07 FLSTC today and it works just fine, went to the dealer about 3 weeks ago and asked about it cause the catalog says for 08 and newer models , but the parts man and the shop man got together looked at the wire harness and it all looked the same to them, so we ordered it and it works great. Now I even have the range ,or distance to empty feature that I did not have before. Needless to say I am excited that it worked.
Old Sep 6, 2010 | 12:32 AM
  #36
AusMongrel's Avatar
AusMongrel
Hi Guys,
I have this speedo coming and I tune using TTS. I have read early in the thready that I need to disconnect the ASSY fuse, but I am a little confused. Does that mean I need to reflash?? Or do you mean I need to pull the fuse if I want to flash in the future?
I am hoping it goes like this, but can you please confirm.
Remove ASSY Fuse
Remove Old speedo
Install new Speedo
Install ASSY Fuse
Ride off into the sunset
Is that correct
Cheers
-J
Old Sep 6, 2010 | 02:59 AM
  #37
nikonf8's Avatar
nikonf8
they look nice but kill the classic look i like them but it wont fly on my bike
Originally Posted by Mathis
I plan to put one on my 2010 Heritage. I wonder why it's $200 cheaper than the analog speedo/tach? I'd think digital would be more expensive.
Old Sep 6, 2010 | 07:05 AM
  #38
Mr. Wizard's Avatar
Mr. Wizard
Originally Posted by AusMongrel
Hi Guys,
Remove ASSY Fuse
Remove Old speedo
Install new Speedo
Install ASSY Fuse
Is that correct
Cheers
-J
It's always best to disconnect the battery when installing/replacing an electrical component but... I think most that have replaced their speedo simply took the old speedo out and plugged up the digital one and done. Personally I like to disconnect the neg battery cable first.
For your flashing question. There is no need to reflash your bike because you installed a new speedo but due to the makeup of this digital speedo, if you do ever flash your bike again, you will need to pull the assy fuse to kill one of the power legs to this speedo or the TTS will come up with an error code.
This new speedo constantly looks for a reserve gas signal from the ECM when powered on and will not release the ECM for flashing. Pulling the ASSY fuse stops this and allows for a clean flash.
Hope this helps.
Old Sep 6, 2010 | 08:43 AM
  #39
AusMongrel's Avatar
AusMongrel
Aha!! Yep - got it. Thanks so much for your help.
I am like you. I pull the battery - better safe than letting the smoke out.
Old Sep 6, 2010 | 09:29 AM
  #40
Softy 103's Avatar
Softy 103
Hope this helps.
So you pull the assy fuse while you are doing the flash? then put it back when you are done.
