TC88 cam install help
Old May 3, 2010 | 12:23 AM
oct1949's Avatar
oct1949
Hope U love them as much as I have...
Great low end and all the way till lines cross, above 82#'s from 2k to 5200 rpms..
thats still with just slip ons...we love the sound and choose to stay with them.
Old May 3, 2010 | 06:47 AM
o/d's Avatar
o/d
Originally Posted by KumaRide
Good job. You forgot to tell us about the most important thing - how does it ride with the 26's?
for me the most important thing was that it actually ran after putting it back together
this was mostly about replacing the tensioners. the cams were just icing on the cake.
but, the power does seem to come on a bit earlier. i really need to do some more riding before i can comment more on the cams.
my speedometer wasn't working on yesterdays ride. so it was hard to tell where i was at.
Old May 3, 2010 | 06:53 AM
o/d's Avatar
o/d
Originally Posted by DR. V-TWIN
You know you can get a press at Harbor Freight for $80. Glad that all came out well.
yeah. i just figured the oven/freezer method was sound......and free.
i still had to buy the cam chain sprocket locking tool, inner cam bearing puller & installer & the alignment screws to the tune of $180.
i made my own tensioner retracting tool.
Old May 3, 2010 | 09:27 AM
KumaRide's Avatar
KumaRide
Glad it worked out for you.
For others and future reference, Auto Zone has free rental on bearing pullers. Use old cams and small rubber mallet to tap in new bearings, they actually go in pretty easy. Depending on where you are, disassy or reassy, regarding the chain sprocket you can put bike in 5th gear with brake on and use a small piece of wood wedge rather than the sprocket locking tool. For oil pump alignment, remove plugs and have some one turn rear turn rear tire in 5th gear while tightening the oil pump by hand, then slowly turn bolts to spec.
Old May 3, 2010 | 12:45 PM
o/d's Avatar
o/d
good advice. i had read about all of that when i was searching the site.
i checked out autozones website, but didn't see any special pullers available. maybe depends on location? maybe they did have them?
so i just bought the puller & installer off ebay for about $125.
the holding tool & alignment pins weren't a lot of money, so they seemed well worth the money to me.
figured even with spending money on tools, it was still cheaper than paying to have the work done, and should assure no f ups.
that & i got to know my bike a little better.
if i were to do it again, i would still use the oven/freezer method.
Old May 3, 2010 | 07:38 PM
coop57's Avatar
coop57
I bought tools to do mine also the specialty tools came from georges Garage and worked great - sold them on E Bay and recovered half the cost.
Habor freigt for the bearing puller - keeping it (handy tool)
Rev- Extend for PCIII to take full advantage of the cams - Ebay also made back 50%
Yes I am a Cheap ol ------ but that is half the fun!
Old May 3, 2010 | 09:10 PM
o/d's Avatar
o/d
i may have to play with the jetting a bit. i'm thinking i would need to go leaner if anything, but i may be wrong?
it didn't run bad though.
took some pictures tonight.
SPARKY01
Yesterday 07:31 PM
kerbykk
Engine Mechanical Topics
19
May 30, 2019 09:29 AM
FASTnLOUDfxdwg
Exhaust System Topics
13
Jun 4, 2013 04:35 AM
BadPiggy
Jan 4, 2009 08:49 AM
Rapture Rider
Nov 25, 2006 07:47 PM
