I have an 09 crossbones and I recently installed a rear turn signal relocation kit. When I turn on the motor everything works fine except the right rear signal. It does not light up unless I put on the blinker and then it will flash. I tried switching bulbs and had same problem. Any ideas? Thanks
Are you using the Run/Stop/Turn module? If so it is a bad module if not you have a wire pinched somewhere in that turn signal. Just went through this not too long ago mine was a pinched wire that burned out the module.
Thanks, I will pull it apart and check for pinched wire. I am not sure what a run-stop-turn module but I will figure out what it is and check that too. Thanks for the help
Sounds like the left is fine and the right is in error... Unless you are using a RUN/TURN/BRAKE unit......Your blinkers should not be on all the time. Only when they blink..
It sounds like you have a short in the wire or a bad ground........Retrace the steps you took on the relocation kit and make sure you spliced the wires together properly.....
