Help oil leak!!!
Old Jul 15, 2010 | 02:38 PM
rossboy83's Avatar
rossboy83
Stage IV
Default Help oil leak!!!
I have an 07 Heritage. There is oil leaking from somewhere just cant find where. It is dripping off of the Primary drain bolt. But here is the kicker, its not the drain bolt. It seems like it is motor oil not primary or tranny. Looks like it is running down behind the primary case. Has anyone else had this problem? Any Ideas? Thanks
Old Jul 15, 2010 | 02:44 PM
Cheesecake's Avatar
Cheesecake
Harley Davidson's don't leak oil....
Are you sure your not riding a Yamaha?
CC
Old Jul 15, 2010 | 02:46 PM
rossboy83's Avatar
rossboy83
Stage IV
Haha Nope Harley. And its too new to have a leak but it does. And dont know where it is comming from. Guess its just time to tear down and find it. Just thought someone might have had a similar situation.
Old Jul 15, 2010 | 02:51 PM
jcallesano's Avatar
jcallesano
Maybe your air cleaner is spitting a lot of oil out...?
Mine spits onto my pipes when I ride hard.
Old Jul 15, 2010 | 02:55 PM
rossboy83's Avatar
rossboy83
Stage IV
No dont think its that cause there is no oil on the side of the bike. Just under it and drips off the Primary drain bolt. I took it to the shop and he just replaced the prmary drain bolt and gasket. That didnt help though still leaking.
Old Jul 15, 2010 | 03:01 PM
BT2121's Avatar
BT2121
Stage III
Default oil leak
could be the shifter shaft seal, happened to me
Old Jul 15, 2010 | 03:19 PM
rossboy83's Avatar
rossboy83
Stage IV
Thanks that could be what it is. Im going to take it back to the shop. But maybe I can point him in the right direction cause he seemed as clueless as me. Even after I told him it wasnt the primary bolt leaking, thats still all he tried fixing on it.
Old Jul 15, 2010 | 03:58 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Shifter shaft seal for sure. It will run down the inside of the primary cover and gather at the primary drain bolt. Mine has been doing that for 5 years. LOL. It only drips off when the bike is extremely hot.
Drew
Old Jul 16, 2010 | 08:52 AM
tk353's Avatar
tk353
i heard something like that but have not had it happen. was told to clean the hole and then poor some loctite in it and let it dry. i thought they were talking about a seam that leaks after a while
Old Jul 16, 2010 | 10:19 AM
FastHoss's Avatar
FastHoss
Happened to mine from running syn.in the transmission.Changed back to regular gear oil and it stopped.
TravisD27
Apr 29, 2018 07:30 PM
Pagman
Oct 21, 2012 07:24 PM
vindyl
Feb 26, 2011 10:31 PM
supr2nr
Ironhead
May 11, 2008 10:53 PM
1941ratrod
May 29, 2006 08:06 PM
