Handlebar Riser Question
Old Sep 22, 2010 | 10:12 PM
Talldog's Avatar
Talldog
Default Handlebar Riser Question
I need to raise the Bar height on my Heritage about 2" and move the bars a little closer to me. The original Riser height is 2", so if I go with 4" curved Risers, that will be about right.
Question is, am I going to have to worry about changing any cables, or am I ok as long as I'm only going 2" higher?
Thanks
Old Sep 22, 2010 | 10:26 PM
Kowan's Avatar
Kowan
Yes those would raise them 2". You shouldn't need new cables.
Old Sep 23, 2010 | 07:57 AM
Talldog's Avatar
Talldog
OK, thanks.
Old Sep 23, 2010 | 10:29 PM
Hrd Rider's Avatar
Hrd Rider
Smile Risers
I put a set of 4" Pullback Risers on my 2008 Heritage this summer. Cables did not have to be changed but dealership suggested replacing the front brake line. Was told existing line would have to be altered and it could possibly cause a stress factor later on. Not to expensive and gave me peace of mind. I used the Harley PBR as it is steel/chrome instead of some of the after market ones that are cast/chrome. PBR really made quite an improvment to rider comfort on the long trips.
2008 Heritage Classic
K&N AC
Rinehart Slip On's
SERT/ Dynoed
Old Sep 23, 2010 | 10:42 PM
AusMongrel's Avatar
AusMongrel
I just put the 4 inch pull backs on my 2010 Fatboy. No need to change cables. Plenty of room on the brake and clutch lines.
Old Sep 24, 2010 | 05:39 AM
Late Bloomer's Avatar
Late Bloomer
I just took 4 in risers off my Heritage. PM me if you are interested in them.
Old Sep 24, 2010 | 06:42 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
You shouldn't need to change things if your only going a couple of inches. But like has already been suggested I would seriously consider replacing the brake line.
With most of the upper half of the stock line being a hard line its all too easy to damage it trying to 'bend it to fit' better.
Better/safer to just get a new one piece flexible braided line in black or chrome from someplace like Magum or even a dealer than screw around with what the factory put on it.
Old Sep 24, 2010 | 08:11 AM
Talldog's Avatar
Talldog
Thanks, but I've already got a set on the way.
Old Sep 24, 2010 | 08:17 AM
Talldog's Avatar
Talldog
Thanks, problem is, I've got a 2011 Heritage with ABS Brakes. I bought a service manual for the bike and it says that anytime the brakes need to be bled, you need to use "Harley Digital Technician". So, looks like I might have to pay the dealer to do the switch.
Was kinda hoping to do it myself and save the labor charge, but it's the brakes, and I don't want to take a chance with them.
Old Oct 17, 2010 | 05:03 PM
mcleod9's Avatar
mcleod9
Do you still have the risers?
mcleod9@mon-cre.net
funbikerchick
Jul 19, 2014 07:34 AM
XKnight
Sep 11, 2013 03:02 PM
cmhd
Aug 10, 2010 04:29 PM
Thewaxmania
Oct 21, 2009 01:18 AM
Rolly1
Mar 8, 2009 07:50 PM
