help whats this wire for
Old Oct 1, 2010 | 08:54 AM
dlongo8241's Avatar
dlongo8241
Default help whats this wire for
I posted this in the tech section but I figured id try it here. I had a screaming eagle air cleaner installed and yesterday I noticed a wire with a capped plug hanging behind the air cleaner. I just stuffed it as far up and out of the way as possible. Just wondering what's it for. I read somewhere its for europe or overseas models. I hope it was ok to stuff it up and out of the way...it looked like crap hanging between the jugs behind the air cleaner. Any body have an idea what it is? If the dealer just tucked it away I would never even known it was there.
Old Oct 1, 2010 | 09:09 AM
Gman in NC's Avatar
Gman in NC
That's what I've heard too, a connection for European tuning.
Old Oct 1, 2010 | 09:30 AM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Zip tie it out of the way. It's for European bikes.
Drew
Old Oct 1, 2010 | 09:47 AM
dlongo8241's Avatar
dlongo8241
Great thanks...I was going to do that but was afraid the zip ties would melt from the heat being between the two jugs....so I just stuffed it up there.....do they make high heat ties?
Old Oct 1, 2010 | 09:58 AM
brettnbama's Avatar
brettnbama
Zip ties should be fine, but if you are really that concerned about the heat, that's what they make the stainless steel zip ties for. The ones some guys use for exhaust wrap
Old Oct 1, 2010 | 10:22 AM
Tired_bird's Avatar
Tired_bird
Yea Ive used ragular zip ties before only inches away from exhaust in a 66 mustangs engine bay, I am sure that gets much hotter then the heat that will be hitting the area your talking about. but as mentioned by brettnbama the stainless steel zip ties are an option.
Old Oct 1, 2010 | 10:27 AM
dlongo8241's Avatar
dlongo8241
great thanks ill use a regular zip tie.....love this forum sometimes
Old Oct 1, 2010 | 10:57 AM
SMF's Avatar
SMF
Ive used the zip ties on the t-700 turbine engines and those get real hot and they never melt bro
Old Oct 1, 2010 | 05:13 PM
Crossb0nes's Avatar
Crossb0nes
Everyone knows the ‘european tuned’ ones are the fast ones right??!!!
Old Oct 1, 2010 | 07:00 PM
SpicOfTheDevil's Avatar
SpicOfTheDevil
the wire/plug is used to operate some kind of valve in the air intake of international models
