Cross Bones Riser Question
Old Jun 26, 2011 | 08:48 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
My set screws are not on the risers themselves, not to cover.
Drew
Old Jun 27, 2011 | 08:20 AM
Ratster's Avatar
Ratster
Helicoils and stainless screen on the bottom of the risers. No problems since.
Old Jun 27, 2011 | 12:34 PM
JoeBobber84's Avatar
JoeBobber84
I was wondering about this.
Old Jul 11, 2011 | 08:14 PM
Mars1's Avatar
Mars1
Time to eat my words, my handelbars started feeling loose on the way home, pulled it into the garage and checked it, the front right screw on the risers stripped out. Dam it. Never had any problems now this.
Old Jul 12, 2011 | 01:43 PM
Mars1's Avatar
Mars1
Just wanted to say thanks to brettnbamma and others. Took my bike back to HD today after the riser screw stripped out on the way home yesterday. There is a problem with the stock risers. HD put heli-coils in the screw holes and replaced the rubber bushings with poly. The poly bushings are "special order" for these bikes so the part # is 0602-0397. This is as far as HD will go to fix the problem. When they inspected the risers a total of 3 screw holes were failing. I know for a fact it was not from over torque. The off the record reccomendation is to replace the risers completly with a solid aluminum type instead of the pot metal OEM.
Old Jul 12, 2011 | 01:54 PM
SBW Cycles's Avatar
SBW Cycles
Had the same problem with my FXSTS. Got new poly bushings and that solved the problems. Bars won't move now!
Vato_FXDB'07
Sep 15, 2012 02:31 AM
rlowride
Aug 27, 2011 08:20 AM
ZeroFiveFour
Mar 11, 2011 09:22 AM
fireinv38
Aug 12, 2010 11:36 AM
darksidebones
Sep 24, 2009 07:43 PM
