Tail light problem with Softbrake Install
Old Mar 25, 2011 | 08:38 AM
billsantos's Avatar
billsantos
[QUOTE=rockchalk08;8094629]Got it. And yes to all of your questions.[/QUOTE
Threads pasted in the night..I re-read your first post and sounds like you did it right. 1 Grey (+) lead from the bike to the old plate light, would be cut from old socket and wired directly to the white (+) lead from the new plate. Black lead to a ground. You left nothing going to the old light socket right ? The bottom bulb is the 2 filament run/brake light. Has 2 wires going to it. Then farther down i read, you found a fuse blown, same connections, fuse blew again. Has to be the new LED plate is shorted..OR, if that tests out ok on it's own, you got a pinched wire shorting out some where..If the new plate checks out ok, rewire it again with all wires exposed.. If works, bundle it up and go have a beer.. you deserve it.
Old Mar 25, 2011 | 09:20 AM
rockchalk08's Avatar
rockchalk08
When I take the LED tag out of the equation, no problems, so I've got a call into Custom Dynamics. Thanks for the help.
emperor wurm
Apr 24, 2012 11:40 AM
rockchalk08
Electrical/Lighting/Alarm
Mar 28, 2011 06:56 AM
Kadorja
Oct 31, 2010 11:44 PM
BigNick
Apr 15, 2010 02:43 PM
bgibbster
Nov 9, 2009 06:07 PM
