Hey fellas.
I'm new to Harley's and have a question. What is the best way to start upgrading the engine on my 2005 Nightrain FSXTB? I have a Big Sucker and Short Shots on it now and want to see more throughout the power band. I would like more low end. I know cams are good but I am not sure which ones would suit me best. What about upgrading the other internals? Im open to any suggestions.
Thanks
2 important criteria missing from your question, budget and riding style. Unlimited budget, the sky's the limit (for a Harley). If you have a $1000.00 budget, then we need to know who's doing the work, you or a shop.
Do you want to do it all at once or in incremental steps?
On any "off the line" HD the air cleaner (AC) and ECU are the number one performance restrictions - IMHO. You already have the big sucker but have you have the ECU remapped to better feed fuel. Since I have no plans at this time for cams, head work or a big bore kit. I just went with a Fuel Moto PowerCommand III and left it at that.
Back in '07 my '05 Train became ill with the infamous valve seal issue. Those were covered under warranty, but I figured since they were tinkering around in the engine, I might as well do some mods. After going back and forth between all the options, I finally decided to NOT do the big bore, but go with cams and some machine work instead. I had .036 shaved off the heads, port work, adjustable pushrods, high comp valve springs and Crane 310-2 cams. At the time, I already had the stage 1, Power Commander and V&H shortshots. It was a completely different bike when I got it back. It now has tons of power pretty much through the whole range, with a bunch of low end get-up-n-go (last dyno was 95T, 90hp) Total cost was somewhere around the $1200 range. I've put about 25,000 miles on it since, with no issues at all. The top end is a bit noisy, but I don't mind it one bit, the lope of the exhaust note more than makes up for it!
P.S. Might also cost you a new rear tire, it's really easy to roast 'em!
EFI or carb? Not sure if FXSTB indicates EFI. With a new breather and exhaust there should be a tuner on it already, unless of course he or the previous owner got a reflash somewhere along the line.
It's carbed. I do think I am going to go the route that J did on his 05. $1200 is within my price range and I want to get most of it done in one sitting. Especially since it is summer and the weather is just right. Thanks guys!
Good way to go and a good price for a 20 HP upgrade.Good thing about the cam and head work only is there's virtually no break-in period. If you don't know a good wrench and machine shop down there, post it here on the forum.
