Rocker rear fender ideas
Old Jul 2, 2011 | 10:25 PM
reddogracing's Avatar
reddogracing
1st Gear
Default Rocker rear fender ideas
i know about heartland and other kits.
But is there a way to take rear fender struts from another softail model and remount the existing rear fender?
looking for a diy method that doesnt cost 2k.
ty all
Old Jul 3, 2011 | 12:28 AM
m i k e's Avatar
m i k e
russ wermount design makes 1 too
Old Jul 3, 2011 | 02:03 PM
reddogracing
1st Gear
thanks, i have seen that as well.
just looks like you could take the struts from another softail and drill some holes and move factory fender up .
guess if no one has tried yet, i need to break out the tape measure and head to the dealership.
Old Jul 3, 2011 | 02:37 PM
user 8373900's Avatar
user 8373900
I guess if you like your rocker to look like a dirt bike with a foot between the tire and fender OK..
Old Jul 3, 2011 | 04:43 PM
Kowan's Avatar
Kowan
The Heartland kit does the same. Most will lower the rear end to avoid the moto-cross look.
Old Jul 3, 2011 | 04:47 PM
user 8373900
We just did several at work.The HL kit is a pretty well thought out system.The Rocker is low as it is,not sure I would want it any lower.
Old Jul 3, 2011 | 04:53 PM
Kowan's Avatar
Kowan
Shotgun Shock to the rescue. Slammed or raised, just a switch away.
Old Jul 3, 2011 | 05:59 PM
08rock's Avatar
08rock
If you want to see a great lookin fender checkout speedsnice
Old Jul 4, 2011 | 05:22 AM
Rocker_Dan's Avatar
Rocker_Dan
ty all
Just a thought but you could get cvo springer struts and use them with a rwd fender(which is the heartland fender anyway)
https://russwernimont.3dcartstores.c...REET_p_52.html
fender is only a few hundred dollars...
Old Jul 6, 2011 | 11:49 AM
lazyboy09's Avatar
lazyboy09
I don't think that would work. The rwd fender has it's struts molded into the fender, I do believe. What about just buying Heartland struts to mount the stock fender? I'm thinking the fender will have to be cut down in the front and a new rock guard figured out as well.
