Harley Springer 4.5 Deg Rake Kit
Old Nov 14, 2012 | 10:21 PM
  #71
20Springer04's Avatar
20Springer04
6th Gear
Originally Posted by chillo
Are you sure you fitted the 7.5 Deg rake kit? As I believe the FSXTS uses a 4.5 Deg kit from Vulcan. The trail with the 7.5 Deg kit on my FLSTS comes in at just under 5''. It did handle slightly different when I first rode it after the install, but you get used to the difference after a few miles. I must stress that it behaves great around the City streets and Country roads...and when I gun it on the motorway, it still behaves perfectly. When you installed your kit, did it feel good and tight with the new bearings..? I experienced no real problems with the install, except removing the original stem was a PITA. The kit I received was very well engineered and the ride is great. Hope you get it sorted...
Sorry, you're right they are the Vulcan 4.5 degree rake. In regards to the bearings, it was snug but once the handle bar and everything else went on it's loose.
Old Nov 15, 2012 | 03:17 AM
  #72
chillo's Avatar
chillo
Originally Posted by Tee⋁10555136
One of the prettiest ***** in the forum. Well done sir, well done!
Tee&Vee and bikerlaw: Thanks for your comments. I'm overseas in S.E.Asia working right now, but I'll take some better photos of the bones and post them on the site when I return home again in January...
20Springer40: I'm assuming you did install the new bearings that came with your Vulcan rake kit? Also, have you tried to adjust the steering stem adjuster nut to allow for proper neck bearing end-play...?
Rgds Chillo...
Old Dec 11, 2012 | 10:51 PM
  #73
dazc76's Avatar
dazc76
I really like the difference the rake makes, looks so much better then stock. I'm gonna have to add that to my list additional mods.
Old Dec 21, 2012 | 07:36 AM
  #74
Tom84FXST's Avatar
Tom84FXST
Originally Posted by DC Mike
This is really the measurement that matters...
The Trail is the distance between where the steering axis hits the ground and where a vertical line down from the center of the front axle hits the ground.
Don't believe that is the correct way to check trail on a springer. The springer already has rake built into it...you need a line from top of the steering pin to the axle...changes the numbers dramatically. Don't have a program to draw perfect straight lines but you get the idea.
Old Dec 21, 2012 | 06:57 PM
  #75
brettnbama's Avatar
brettnbama
chillio, can you post some close up pics of your rear signals when you get back?
Old Dec 26, 2012 | 07:18 AM
  #76
tim1511's Avatar
tim1511
Stage I
Perhaps, this site gives you the right information.
awge.bravepages.com/minichoppers/trail/Rake_Trail.htm
Old Jan 7, 2013 | 07:20 AM
  #77
chillo's Avatar
chillo
No problem brettnbama... I'll do that for you when I get back home next weekend...
Old Jan 21, 2013 | 03:57 PM
  #78
20Springer04
6th Gear
Rgds Chillo...
Chillo, sorry for taking so long to reply..
to answer your question, yes on both. new bearings and adjusted the neck bearing end play.
after messing around with the front suspension a gazillion times i started looking at the rear suspension to see if that was causing my bike to bounce around at high speed turns. i raised the rear so that the frame is leveled and the bouncing got better but if i hit a hard bump while turning right it'll bounce.
my thoughts.... the FXSTS front wheel is not centered when you reference it to the fork, it's offset to the left. i remember when i had the factory rear wheels on it was off centered as well, to the right if you are looking at it from the front of the bike. with the 250mm rear i have now, will that cause some kind of front to rear alignment issue? I'm ready to put the rake back to stock but i just want to rule out all possibilities before doing all that work and find out later that the front has nothing to do with the problem i'm having.
Old Feb 2, 2013 | 07:47 AM
  #79
scooter223's Avatar
scooter223
Hi guys,
I'm brand new here and this particular thread popped up numerous times when I was searching for "springer rake" several months ago. Anyhow, I got a hold of the Vulcan website and finally ordered and installed the 4.5° rake kit. Not too hard to install, but a little finiky to set up. In the end, it worked out very nicely. I am happy I did it to my 04 springer softail.
Are there any problems that I ought to know about from those of you who have had the kit installed for a while?
Thanks,
JS
Old Feb 2, 2013 | 07:58 AM
  #80
Mill908's Avatar
Mill908
SON OF A, well i think that just got added to the list. My kids and their dwindling college fund thanks all of you showing me this option.
