anyone trust this lowering kit?? cheap lowering kit
Old Jul 18, 2011 | 02:51 PM
NASTY LSX's Avatar
NASTY LSX
Originally Posted by kiwideuce
yes i have used the bolts!!! this is how i it!!
https://www.hdforums.com/forum/softa...nty-bucks.html
bit of a hard ride,422 would be much better! but hay,$20
Whats a 422 LOL
Old Jul 18, 2011 | 04:01 PM
jed1069's Avatar
jed1069
Progressive 422 shocks
Old Jul 18, 2011 | 04:21 PM
z06elmo's Avatar
z06elmo
I had the stock shocks with the lowering bolts to what seems like 2.25" or so. The ride was as if i was on a hardtail. My A$$ would be sent off the seat in some bumps and my lower back was dying.
I went to 422 and now have the bike lowered about 1.4" or so and it's a much improved ride.
Old Jul 18, 2011 | 04:26 PM
klf33's Avatar
klf33
The cheap is the same as the expensive, OK, maybe check the Steel grade but they should all be the same.
The ride quality will suck, but the expensive one will give you the same ride quality.
I had the cheap one for 3 years then went to 422's.
If you are solo and do not drop it all the way down you will be OK.
Old Jul 18, 2011 | 08:00 PM
funnythebunny's Avatar
funnythebunny
I actually went with the kit from http://www.softailloweringkit.com and am not only happy but impressed. There's no need to remove the shocks. I lowered it 1.5" in a few simple steps.
Just jack the bike, remove the 2 front nuts, raise the rear wheel, remove and replace the front cups,remove the steel sleeve from the threaded shaft, insert a 1/2" collar spacer, lower the rear wheel and replace the front nut with the provided one. Easy 20 minute job, without needing to remove or disassemble the rear suspension.
There's a video in their website; watch it a couple of times and be amazed how simple it is.
Old Jul 18, 2011 | 08:24 PM
Scheers44's Avatar
Scheers44
I run a $20 ebay special lowring kit on my bike from 07 till 3 weeks ago. 19 thousand miles no problems! Only reason I swapped was to go SS airride.
Old Jul 18, 2011 | 08:49 PM
MicahB339's Avatar
MicahB339
I just ordered 3
Can't go wrong for 16 bucks
kingjoey5000
Apr 8, 2013 09:30 PM
netvampire
Jun 15, 2012 04:37 PM
eddieholmes
Mar 31, 2011 07:28 PM
amontances
Jul 10, 2007 04:09 PM
JSW
Feb 1, 2006 09:44 PM
