Dead Brake/Tail light on a 2011 Fatboy lo
Old Jul 28, 2011 | 09:14 PM
glock221's Avatar
glock221
Default Dead Brake/Tail light on a 2011 Fatboy lo
It is not working. All of the other lights work. I pulled the seat to look for fuses. I only found a block with 3 fuses. Main Fuse, Battery fuse 15 amp and 1 other 15 amp. Is there a fuse specifically for the Brake/Taillight? If so where is it? Or, do you think I have a wiring problem?
Old Jul 28, 2011 | 09:20 PM
HEMI Army's Avatar
HEMI Army
Does the running light work? Does it just not go brighter when you hit front or rear brake or is completely out?
Old Jul 28, 2011 | 09:25 PM
glock221's Avatar
glock221
running light is dead also. does not light up at all. I revved it a bit and wiggled wires, but no light at all.
Old Jul 28, 2011 | 09:34 PM
vheflin's Avatar
vheflin
Is it an LED or conventional bulb? If a bulb, is it burned out?
Old Jul 28, 2011 | 09:36 PM
Keithhu's Avatar
Keithhu
Warranty, take it in and let them deal with it.
Old Jul 28, 2011 | 10:27 PM
Rakthi's Avatar
Rakthi
+1, the 2011 bikes got the can bus system. Not something you can easily mess around with as all controlled by the ECM, therefor no fuses like on older bike.
Check under your rear fender, could be the wiring harness touching the tire?
Old Jul 28, 2011 | 10:30 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
What about the bulb itself?
Drew
Old Jul 28, 2011 | 10:35 PM
Brutus01's Avatar
Brutus01
Also on the 2011s there is a way to reset the lights. This had to be done on mine after a new tail light was installed. I dont remember exactly how they did it but it may be in the owners manual. If not, maybe someone with a service manual can look it up for you.
Old Jul 28, 2011 | 10:51 PM
ChromeJunkie's Avatar
ChromeJunkie
Take it in and have the dealer look at it. Bike is still under warranty.
Old Jul 28, 2011 | 11:47 PM
glock221's Avatar
glock221
Thanks for all of the replies. I am a dummy. It was the bulb itself. I had it dynotuned about a week ago, and I am assuming all of the vibrating caused the bulb to blow. The next step was to take it in to the dealer, although I wanted to ride to work tomorrow. Now I can. Thanks everyone.
Damien Bessent
Sep 20, 2022 03:36 PM
Ashnic
Jan 16, 2019 07:55 PM
koolbreez
Electrical/Lighting/Alarm
Jul 22, 2018 09:03 AM
Schaub85
Jul 23, 2012 07:58 PM
bigdog_tim
Mar 19, 2007 12:17 PM
