ther is alot of info on this, but have not been able to find the answer to my question.
my 2006 heritage with a PCIII USB has the delayed start, has anybody upgraded to the PC-V retrofit. Does it fix the delayed starting issue?
Like it has to crank more before it fires? My bike did that with the PCV. It was only a few more cranks, but it was always longer than with just the OE ECU. Now that I'm on a PV the cranking is back to normal. It might be that way with any piggyback system.
ther is alot of info on this, but have not been able to find the answer to my question. my 2006 heritage with a PCIII USB has the delayed start, has anybody upgraded to the PC-V retrofit. Does it fix the delayed starting issue?
__________________
2006 Heritage
Originally Posted by RocketRocker
Get the motor tuned, sometimes a canned map wont be right for yer ride.
Did U read the post at alll..... he said He has a PC111, He said nothing at all bout a canned map..
