easy brackets for flstc?
Old Dec 28, 2011 | 09:09 AM
jlasoftail's Avatar
jlasoftail
Default easy brackets for flstc?
Hey guys, been a while since I've been on here, but things have calmed down and now it's time to wait out the winter and pick up a few things for the bike. So I'm looking for a quick detach setup for my '09 heritage bags. I looked at the easy brackets, but I'm worried the bags will stick out to far, and I'm not sure if it allows for the lower bag support to stay in use. Have you guys had any luck with this setup, or can you recommend another? Thanks for the help...
Old Dec 28, 2011 | 09:23 AM
Motown Strag's Avatar
Motown Strag
I use these on my flstni, they stick out enough to clear my swingarm covers so it works great for me. If you don't use your bags much you can put the stock fender bolts back on in a couple minutes, me personaly I don't mind the docking hardware.
Old Dec 28, 2011 | 11:07 AM
shineybike's Avatar
shineybike
I have that setup on my '04 Heritage. I drilled out the rivets that hold on the stock bag supports and then mounted the easy brackets. I have not had any issues with not having the lower support. Most of the time I ride without the bags. I haven't tried it but you might be able to keep the stock mount in place and mount the easy bracket between that and the quick release pegs on the fender. Love being able to remove the bags in seconds. They stick out a little further than stock but it doesn't bother me.
Old Dec 28, 2011 | 11:15 AM
Benway's Avatar
Benway
Originally Posted by Motown Strag
If you don't use your bags much you can put the stock fender bolts back on in a couple minutes...
This is my solution. Just takes a couple minutes to bolt them on when I need them.
Old Dec 28, 2011 | 03:22 PM
jlasoftail's Avatar
jlasoftail
I've been doing that, and I know it doesn't take long, but most of the time I find I just can't be bothered to unbolt them, and mostly what I want the quick detach setup for is when I'm on the road, I can pop the bags off and take them into the hotel with me instead of unpacking everything... I'd love to hear from someone with a different product for comparison.
Old Dec 29, 2011 | 03:55 PM
jlasoftail's Avatar
jlasoftail
Really? none of you other Heritage guys have quick detach bags?
Old Dec 29, 2011 | 08:00 PM
waterdog's Avatar
waterdog
No, but I'm looking for some input on this also for my 2007 Heritage.
Searching the threads on the forum turned up info on several brands:
Ghost Brackets
Easy Brackets
Bubbas Brake Brackets
Cycle Visions BareBacks
Boss Bags QD Chucks
Lots of complains about Easy Brackets setting bags too far outboard from stock.
Lots of complaints about Bubbas customer service - I think they may be out of business now even.
I'm most interested in the Boss Bags Quick Detachable Brackets, though they are expensive. It appears that these still have a contact point for the lower front attach point, though it does not appear that it actually connects at the point, just rests.
See bottom of this page - http://www.bossbags.com/heritage.html
I have the Boss Bags Heritage Stiffeners installed in my bags and they are great.
Customer service from them was great a couple years ago but I haven't heard much feedback on the forum on the "air chuck" style Quick Disconnects for the Heritage bags.
Anybody got some real world feedback on the Boss Bags Quick Detachable Brackets?
Old Dec 30, 2011 | 05:57 AM
MikeZ's Avatar
MikeZ
I saw the Easy Brackets on a Heritage this past summer. I think they make the bags stick out to far and they look cheap -- and they are not. Just my .
Old Dec 30, 2011 | 07:09 AM
brenn's Avatar
brenn
I got Barbacks for a heritage off Ebay ($30, new in sealed package) so I use those (fit my FXST perfectly). They make the bags stick way out, since I use them with docking sissy bar hardware, but that's the price of being able to take them off.
Old Dec 30, 2011 | 07:55 AM
FBFletch's Avatar
FBFletch
I used a set of Easy Brackets to mount a set of leather bags on my Fat Boy. Mounting on a Heritage would be the same. I reinforced the inside of the bag with a metal plate so the bags would not sag. I basically attached the plate to the inside of the bag with 3M Trim Adhesive (yellow snot) and then drilled holes through the back of the bags to match up with the mounting holes in the Easy Bracket. I don't think they stick out too far. As someone pointed out, the only reason they stick out as far as they do is because of the detachable sissy bar hardware. The only thing holding them on is the Easy Brackets. No other support is required. Here's some pics:
